jeepmjga Posted August 15, 2023 Posted August 15, 2023 Anyone else with their crossover steering have their rods just kinda flopping around when installed. Got everything tight and loctited, got the heims clocked as far as i can but there is still a good bit of movement in the heims so it sounds terrible when I'm going wheeling or going over speed bumps on pavement. Been searching but can't find anyone else with the issue really. Maybe i got a bad set of heims? Emailed cavfab and they said "thats normal try clocking the heims more". can't be right it sounds like the front end is going to come apart when i hit a big bump.
ghetdjc320 Posted August 15, 2023 Posted August 15, 2023 Do you have the right size misalignment spacers? How is the bolt to heim cylinder bore fit?
75sv1 Posted August 15, 2023 Posted August 15, 2023 I didn't use hiems on my 1-ton cross over steering. I used the 1-ton GM TREs. I could see that for Offroad, the heims would give better articulation though. I did purchase the IRO steering set up. It came with heims. Threads ar 3/4x10 or something like that. I found that ES150 TREs have the same threads. The taper is between stock and 1 ton.
jeepmjga Posted August 16, 2023 Author Posted August 16, 2023 19 hours ago, ghetdjc320 said: Do you have the right size misalignment spacers? How is the bolt to heim cylinder bore fit? I just installed what came in the kit so I assume they are correct. The hole size was a nice tight fit, reamer didn't wander or anything. The problem is more that the entire assembly kinda flops up and down, not side to side. Steering feels nice and tight, no DW or wandering or anything.
jeepmjga Posted August 16, 2023 Author Posted August 16, 2023 13 hours ago, 75sv1 said: I didn't use hiems on my 1-ton cross over steering. I used the 1-ton GM TREs. I could see that for Offroad, the heims would give better articulation though. I did purchase the IRO steering set up. It came with heims. Threads ar 3/4x10 or something like that. I found that ES150 TREs have the same threads. The taper is between stock and 1 ton. Yea I had the thought of using TRE's instead but I had to ream the knuckles to install the heims. Whatever next setup I use when I swap out the front axle will def be TRE's
ghetdjc320 Posted August 16, 2023 Posted August 16, 2023 1 hour ago, jeepmjga said: I just installed what came in the kit so I assume they are correct. The hole size was a nice tight fit, reamer didn't wander or anything. The problem is more that the entire assembly kinda flops up and down, not side to side. Steering feels nice and tight, no DW or wandering or anything. Reamer? So your using tie rod ends or heims? Or was the reamer so you could install some sort of insert?
jeepmjga Posted August 16, 2023 Author Posted August 16, 2023 2 minutes ago, ghetdjc320 said: Reamer? So your using tie rod ends or heims? Or was the reamer so you could install some sort of insert? Using heims. Used a reamer to drill the knuckle to 5/8.
ghetdjc320 Posted August 16, 2023 Posted August 16, 2023 Gotcha, I was thinking tapered reamer for TRE’s
