88towmanche Posted August 7, 2023 Author Share Posted August 7, 2023 27 minutes ago, Pete M said: the larger diameter shaft is actually weaker. plus has that silly rubber vibration damper inside. Boom - this is critical intel - if I was guessing I probably would have used the larger assuming it was stronger. Thnx Pete! Link to comment Share on other sites More sharing options...
Pete M Posted August 7, 2023 Share Posted August 7, 2023 it's only bigger because they wanted to use the rubber thingie for the longer 2wd shafts so as to reduce vibrations. Link to comment Share on other sites More sharing options...
The86manche Posted August 7, 2023 Share Posted August 7, 2023 2 hours ago, 88towmanche said: Sweet - no idea what they go for but I'm good for market price & shipping - just let me know. Honestly, no idea either. I'd probably just say $15 plus shipping honestly. Link to comment Share on other sites More sharing options...
88towmanche Posted August 7, 2023 Author Share Posted August 7, 2023 1 hour ago, The86manche said: Honestly, no idea either. I'd probably just say $15 plus shipping honestly. Works for me - will DM you. Link to comment Share on other sites More sharing options...
88towmanche Posted September 6, 2023 Author Share Posted September 6, 2023 Slowly plugging away at this - collecting parts (it's the little stuff....) Cracked the cover on the diff - what am I looking at here - PO said something about a Yukon posi - this looks like their Dura Grip LS - clutch style. Anyone running one of these? Link to comment Share on other sites More sharing options...
88towmanche Posted September 11, 2023 Author Share Posted September 11, 2023 More progress.... Got the cover (new) on the diff - did a quick tape/spray job and clear coated the whole thing. Used a couple of studs to stand off the LSV bracket (thanks to The86manche for the bracket) getting the brake lines sorted - have some cunifer line and ss gravel guards to diy replace the hard lines on the axles....but the ones on the '88 are pretty clean so might just use those. Waiting on a few more parts - have an airbag kit plan to install but with the shackle lift need spacers for the airbags - those are on the way... Link to comment Share on other sites More sharing options...
The86manche Posted September 11, 2023 Share Posted September 11, 2023 Looks good! Glad I could help! Link to comment Share on other sites More sharing options...
88towmanche Posted February 5, 2024 Author Share Posted February 5, 2024 Still hacking away at this - bending and flaring brake lines Using the nickel-copper tubing makes it easier to form good flares Link to comment Share on other sites More sharing options...
88towmanche Posted February 5, 2024 Author Share Posted February 5, 2024 Used fork extensions on the Hyster to reach up under there and pull the old axle out while truck is on the lift. Link to comment Share on other sites More sharing options...
88towmanche Posted February 5, 2024 Author Share Posted February 5, 2024 new 410 44 is in place - new ubolts & hardware, working on airbags & waiting on cut down driveshaft. Link to comment Share on other sites More sharing options...
