72cut Posted June 29, 2023 Share Posted June 29, 2023 Going to be replacing my radiator, should I replace water pump and fan clutch even though fan seems to spin fine and I don't see current pump leaking?. Link to comment Share on other sites More sharing options...
Smokeyyank Posted June 29, 2023 Share Posted June 29, 2023 Water pump might as well especially if you don't know when it was replaced last. Fan clutch if it wiggles otherwise leave it. Also good time to consider a open system vs closed depending on year Link to comment Share on other sites More sharing options...
gvthnks Posted June 29, 2023 Share Posted June 29, 2023 With the radiator out, it's so easy to do the waterpump and thermostat too. I would. Link to comment Share on other sites More sharing options...
72cut Posted June 29, 2023 Author Share Posted June 29, 2023 It's an 88 doing this on budget Link to comment Share on other sites More sharing options...
72cut Posted June 29, 2023 Author Share Posted June 29, 2023 Thanks Link to comment Share on other sites More sharing options...
72cut Posted June 29, 2023 Author Share Posted June 29, 2023 Which degree stat? Link to comment Share on other sites More sharing options...
big66440 Posted June 30, 2023 Share Posted June 30, 2023 195 is the factory temperature Link to comment Share on other sites More sharing options...
72cut Posted July 3, 2023 Author Share Posted July 3, 2023 Thanks Link to comment Share on other sites More sharing options...
