Clutch Pedal Arm, pulled and welded.
10 hours ago, cruiser54 said:
I bet it won't!!
The manufacturer, only placed 3 short beads around the circumference of that cylinder and where the welds were not, weakened the steel. IMHO, that was not to smart AMC/Jeep!
This seems like more than what is described as factory(welds), but I’m not sure if it is.  I’m assuming Jim did this weld, but it’s only halfway around( it’s fully around on the pedal side). Should I just finish the half weld or is this more than enough?
