Replacement MJ Mud Flap Brackets - Stainless Steel - $79 w/ Hardware
In stock and ready to ship.
One full set of replacement brackets for your Jeep Comanche MJ mud flaps including new hardware kit.  Typically, the rubber mud flaps are very resilient to wear, however the original steel brackets had a tendency to rust and degrade over time.
Includes (2) front brackets and (2) rear brackets for 1986-1992 Jeep Comanche MJ.  CNC designed and laser cut using 16 gauge stainless steel.  All necessary hardware included (also stainless steel).
Rear brackets are an improved 1-peice design over the original 2-peice configuration.
These are the brackets found in OE mud flap kit 82200793 (front) and 82200795 (rear).
Brackets can be left raw or painted if desired.
https://boxyjeep.com/products/jeep-comanche-mj-mud-flap-bracket-kit-1986-1992
1 hour ago, ghetdjc320 said:
Yes, please repop the actual flaps!!! I have a lot of info on them if you need detailed drawings. Great to have the hardware though too. :L:
i don’t need them yet, but save me a set for tomahawk
Thanks—yes I’m planning to.  I’ll dm you.
