Warren99 Posted May 11, 2023 Share Posted May 11, 2023 Now that I have an 87 Chief interior( including the dash and whole harness), I’m trying to put my aftermarket radio back in. Did the radio harness change wire colors at all from 87 to 89? I'm using my 89 book but either the wires are diff colors or I just don’t understand how to interpret it properly. i need someone to explain how to interpret it, or send me the radio wire diagram from an 87. Thanks Link to comment Share on other sites More sharing options...
Ωhm Posted May 11, 2023 Share Posted May 11, 2023 MJ_1987_Electrical_Manual_1.pdf Link to comment Share on other sites More sharing options...
Warren99 Posted May 11, 2023 Author Share Posted May 11, 2023 Thank you! Link to comment Share on other sites More sharing options...
Warren99 Posted May 11, 2023 Author Share Posted May 11, 2023 Just to make sure, when looking at the speakers, A is positive and B is negative right? Link to comment Share on other sites More sharing options...
Ωhm Posted May 11, 2023 Share Posted May 11, 2023 40 minutes ago, Warren99 said: Just to make sure, when looking at the speakers, A is positive and B is negative right? Seems to be true except for Left Door Speaker. Gotta love these manuals. Both 87 & 88 show the same. Typo maybe, best I can do. Look at your speakers, that will be the same. Link to comment Share on other sites More sharing options...
schardein Posted May 11, 2023 Share Posted May 11, 2023 I remember reading somewhere, that if a speaker is not marked positive and negative on the terminals, you can use a 9 volt battery and some short jumper wires as a test. Touch the leads to the terminals of the speaker momentarily. The speaker woofer will move. If it moves out, you have the polarity correct. If it moves back, the leads are backwards. Reverse them and try again to confirm. I think I read that in the electrical tips column in the old JP magazine. Link to comment Share on other sites More sharing options...
Warren99 Posted May 11, 2023 Author Share Posted May 11, 2023 26 minutes ago, Ωhm said: Seems to be true except for Left Door Speaker. Gotta love these manual. Both 87 & 88 show the same. Typo maybe, best I can do. Look at your speakers, that will be the same. Yea I was confused as to why A was suddenly black. I'll treat it as a misprint/typo Link to comment Share on other sites More sharing options...
Warren99 Posted May 12, 2023 Author Share Posted May 12, 2023 What does BLK w/TR mean? From looking at my wires it seems like w/TR just means with a white stripe, but in the diagram I also saw example like BLK w/WHT. Link to comment Share on other sites More sharing options...
Ωhm Posted May 12, 2023 Share Posted May 12, 2023 It means at the time of print the trace (TR) wire color was unknown. But what was known was wire had a tracer on it. Some say if the harness builder was out of that color, they just used another color for the tracer. Link to comment Share on other sites More sharing options...
Warren99 Posted May 12, 2023 Author Share Posted May 12, 2023 Oh ok so TR essentially just means theres a stripe of some color? Link to comment Share on other sites More sharing options...
Ωhm Posted May 13, 2023 Share Posted May 13, 2023 Yes. Wire will/should have a tracer color on it. Link to comment Share on other sites More sharing options...
Htchevyii Posted February 2, 2025 Share Posted February 2, 2025 I just went through this on my '88. My wires did not match most diagrams that I found, but did match this one. Link to comment Share on other sites More sharing options...
