91Pioneer Posted May 8, 2023 Share Posted May 8, 2023 I broke one of my axle vent plastic pieces when I was trying to change the hose. Does anyone have a part #? Prefer OEM part, if not I may have to look for a brass fitting or something. It’s kind of urgent. This is a pic of the good one:  Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 8, 2023 Share Posted May 8, 2023 In the axle and up above-J5352955 Â Link to comment Share on other sites More sharing options...
91Pioneer Posted May 8, 2023 Author Share Posted May 8, 2023 Hmmm  Link to comment Share on other sites More sharing options...
91Pioneer Posted May 8, 2023 Author Share Posted May 8, 2023 Fortunately I have one of the two clips, so the good clip can go into the diff so I don't have to mess around there, and I can mod something up for the box / vent end of it. Â It's about a 100 mile round trip to the junkyard. I would think the 90 XJ would have the same clip, eh? Link to comment Share on other sites More sharing options...
gogmorgo Posted May 8, 2023 Share Posted May 8, 2023 Is this for a D30? I haven’t really looked at them, but iirc the rear one is a fancy threaded barbed fitting that also holds the rear brake T to the axle. It tore the threads out of my ZJ’s D35, so what I did was drill and tap for a larger bolt that still fit through the hole in the T, drilled down through the center of that bolt to hollow it out and then drilled the bolt head out to accept 1/8 npt threads for a hose barb. The end product sure wasn’t pretty, but it did work.  For what it’s worth, I’m seeing 83504653 for the D30 fitting.  Link to comment Share on other sites More sharing options...
91Pioneer Posted May 9, 2023 Author Share Posted May 9, 2023 It's for a rear diff, stock 2WD 89 MJ. So... Dana 35 maybe? I'm not up on all the correct tech specs / lingo all the time. Link to comment Share on other sites More sharing options...
boxyjeep Posted May 9, 2023 Share Posted May 9, 2023 Just tap to 1/4” NPT and use a brass fitting. Link to comment Share on other sites More sharing options...
