1J7FT66L2LL109789
schardein
*Q7 CLOTH LOW-BACK BUCKET SEATS
-SA Charcoal
171 Zone 71-Los Angeles
1AA U.S. Dealer Retail
4AF
5KR Midland Corporation
ADA LIGHT GROUP
ALR
APA MONOTONE PAINT
ARM RADIO AM/FM CASSETTE
BA1 100 AMP ALTERNATOR
BCY 475 AMP BATTERY
BGA POWER FRONT DISC/REAR DRUM BRAKES
CAC LOW BACK BUCKET SEATS
CDB RECLINING FRONT SEATS
CKA CARPETS - FLOOR AND CARGO AREA
CSR PASSENGER ASSIST HANDLES
CUF FULL LENGTH FLOOR CONSOLE
DBB ALL MANUAL TRANSMISSIONS
DDQ 5-SPEED MANUAL TRANSMISSION
DMM 3.07 REAR AXLE RATIO
DRK DANA 44/226MM REAR AXLE
DSA ANTI-SPIN DIFFERENTIAL REAR AXLE
EAA ALL ENGINES
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC TINTED GLASS WINDOWS
GBB TINTED WINDSHIELD GLASS
GCB FRONT DOOR TINTED GLASS
GEH FIXED DOOR VENT GLASS
GFD REAR SLIDING WINDOW
GNA REAR VIEW DAY/NIGHT MIRROR
GNB DRIVER SIDE ILLUMINATED SUN VISOR
GNC SUN VISORS W/ILLUM VANITY MIRRORS
GRZ LEFT REMOTE MIRROR
GSZ RIGHT REMOTE CONTROL MIRROR
GTZ MANUAL REMOTE MIRRORS
HAA AIR CONDITIONING
JAY DO NOT USE - SEE JP, KA CLASSES
JCA 85 MPH PRIMARY SPEEDOMETER
JGB
JHA VAR INTERMITTENT WINDSHIELD WIPERS
JJA CIGAR LIGHTER
K2B STRIPE/BADGE/MOLDING/COLOR
K3R STRIPE/BADGE/MOLDING/COLOR
KLH
LAJ HEADLAMPS ON WARNING CHIMES
LAP SHIFT INDICATOR WARNING LAMP
LBB COURTESY LAMPS
LBC GLOVE BOX LAMP
LBD ASH TRAY LAMP
LBE AMBIENT LIGHT
LCJ DOME/READING LAMP B-PILLAR
LDH U/HOOD, REMOVABLE/RECHARGEABLE LAMP
LHD HEADLAMP OFF TIME DELAY
LMA HALOGEN HEADLAMPS
LNJ FRONT FOG LAMPS
MB1 Black Front Bumper
MBJ BLACK BUMPER
MCA
MDA Front License Plate Bracket
MFK Body Color Grille
MHA Black Windshield Moldings
MMC
MMG Belt Moldings
MMK
NAE California Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Steering
SCG Leather Wrapped Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TBB Full Size Spare Tire
TBM Tire Carrier Winch
TRM Tires
WJH 15X7 Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Build date 7/30/89
Body code TL61
Sold by DON-A-VEE JEEP-EAGLE, BELLFLOWER CA
21 hours ago, eaglescout526 said:
Build date 7/30/89
Body code TL61
Anything in there to specify an Eliminator?
I can confirm it had the D44, 3.07, Limited slip.
1 hour ago, eaglescout526 said:
That whole front end has a lot of good parts.
Header panel was cracked even though you can't see it.  Probably repairable if someone wanted to make the effort.  Sad thing is the whole truck was repairable- it definitely could have been saved.
2 hours ago, fiatslug87 said:
Yes, it is an Eliminator. 6 in the sixth position of the VIN for 89-92 models.
How was the rear bumper?
It was dented.
Odd thing, manual trans, but the steering column didn't have the "key release" lever.  It seemed like it was an auto column from a XJ, no key release lever, but also no shift lever (console shift).  I always look at steering columns, and can't ever recall seeing a manual without the key release lever.
10 minutes ago, eaglescout526 said:
Someone took a whole loaded MJ and threw it away.
Yep
11 minutes ago, fiatslug87 said:
The end caps look decent and it has a hitch! I hope you pulled it and the tailgate.
I only had so much room, and so much time.  But yes, I have the tailgate, and rear cab carpet.  Left the hitch, and a lot of other valuable stuff.
Those are the factory Eliminator wheels in the back of the bed.  Along with an extra hood (straight) and the driver side tail light lens.
