KeelybLost Posted May 4, 2023 Posted May 4, 2023 Hello, first time posting here. I am not sure if I am posting this in the right subsection. So I have a 4wd 5spd '88 Comanche that I got in today and the reverse gear just isn't working. No sounds, no loud "bangs" at any point. This is a first for me so before I get to opening this pig up and getting myself into trouble...do you guys have any insights as to why this may have happened? Also, simultaneously my gas gauge stopped working. Unlikely these are related but thought I'd throw it out there. Thank you in advance.
Pete M Posted May 4, 2023 Posted May 4, 2023 Is it not going in to gear? Or goes in but doesn't move backwards?
KeelybLost Posted May 4, 2023 Author Posted May 4, 2023 2 hours ago, Pete M said: Is it not going in to gear? Or goes in but doesn't move backwards? I tried it again to get a more specific idea for you and now it is grinding and kicking back out of gear. Didn't do anything this morning.
pizzaman09 Posted May 4, 2023 Posted May 4, 2023 Does the BA10/5 have a reverse lock out mechanism? Try shifting through 1-5th then back into say 3rd prior to shifting into reverse.
KeelybLost Posted May 4, 2023 Author Posted May 4, 2023 1 hour ago, pizzaman09 said: Does the BA10/5 have a reverse lock out mechanism? Try shifting through 1-5th then back into say 3rd prior to shifting into reverse. I'll try this and report back. Side note, how interchangeable is the BA10/5 from other models/years? In preparation I can't find this model year BA anywhere but plenty of wranglers with the BA.
Pete M Posted May 5, 2023 Posted May 5, 2023 The ax15 is the usual swap upgrade. The link in my signature should have info on that.
