ktmall07 Posted April 12, 2023 Share Posted April 12, 2023 I’m finally finishing up an A/C retrofit, and I’m kinda stuck. The truck didn’t have A/C originally, but had a dealer install a generic system some time. I’ve replaced everything with a mostly stock system, except for the expansion valve, which I replaced with a new version of what was originally on there (some 4 seasons part) because to fit a stock expansion valve I’d have to tear into the firewall Andy replace the whole system, and I want to avoid that until I can’t. I need a new hose from the receiver drier to the expansion valve, with the same fitting on both sides unlike the stock system that has the thin fastener on the expansion valve side. Has anyone seen a hose like this, and does anyone know where to find one? I need a longer version of the hose on the left in the first picture, on the right is a stock hose that is long enough, but has the wrong fitting on the expansion valve side. Link to comment Share on other sites More sharing options...
Limeyjeeper Posted April 12, 2023 Share Posted April 12, 2023 Try Jeep Air but if I remember correctly this line is very hard to find. Link to comment Share on other sites More sharing options...
88towmanche Posted April 12, 2023 Share Posted April 12, 2023 Have one made at a local hose & fitting shop - we've done it many times for marine applications (boats are all funky and one-off) Not that much $$ Link to comment Share on other sites More sharing options...
AZJeff Posted April 12, 2023 Share Posted April 12, 2023 1 hour ago, 88towmanche said: Have one made at a local hose & fitting shop - we've done it many times for marine applications (boats are all funky and one-off) Not that much $$ This is the best solution Link to comment Share on other sites More sharing options...
ktmall07 Posted April 13, 2023 Author Share Posted April 13, 2023 That’s what I’ve decided. I cut out the fittings from the old hose and crimping, and am taking it to a shop to have a custom one made. Thanks guys! Link to comment Share on other sites More sharing options...
