JeepcoMJ Posted December 21, 2007 Share Posted December 21, 2007 Eagle, I agree with you 100%. but, most people abuse their trucks more than you so anything to help them with upkeep to counter the abuse is a great thing. Link to comment Share on other sites More sharing options...
Tonedef131 Posted December 21, 2007 Author Share Posted December 21, 2007 Well I finished putting all of the parts on this afternoon and wanted to thank everyone for their advice. I am glad that I went with the higher quality ball joints since that is one job I NEVER want to do again. But the truck goes down the road and turns so smooth now. I have never seen u-joints that bad, one the caps didn't even have bearings left in it :eek: Link to comment Share on other sites More sharing options...
carnuck Posted December 21, 2007 Share Posted December 21, 2007 I use the non-greaseable joints and hand grease them with the good stuff before assembling. Link to comment Share on other sites More sharing options...
Tonedef131 Posted December 21, 2007 Author Share Posted December 21, 2007 I use the non-greaseable joints and hand grease them with the good stuff before assembling.I got the greasable ones but they have a wierd zert that my grease gun doesn't fit. normally they have like a nipple sticking out, but these are a flat head screw with a small hole recessed within. Does anyone know what kind of tip I need to grease these? Link to comment Share on other sites More sharing options...
mjeff87 Posted December 21, 2007 Share Posted December 21, 2007 Use a needle tip Image Not Found Link to comment Share on other sites More sharing options...
Tonedef131 Posted December 21, 2007 Author Share Posted December 21, 2007 So that will just insert right into the zert? Thats perfect, thanks! Link to comment Share on other sites More sharing options...
mjeff87 Posted December 21, 2007 Share Posted December 21, 2007 yeah, just push it into the center of the fitting while pumping. Use a rigid line on the output of the gun, not a flexible one or else you're gonna need three hands ;) The gun will be hard to squeeze, but it will flow grease thru the needle tip, trust me. Another alternative, if you don't want to buy the needle fitting (but it is a good tool to keep in the box), is unscrew the flat fitting and insert a nipple fitting and use the regular tip on the grease gun. When the joint is packed, swap the flat fitting back in. Jeff Link to comment Share on other sites More sharing options...
Tonedef131 Posted December 21, 2007 Author Share Posted December 21, 2007 Another alternative, if you don't want to buy the needle fitting (but it is a good tool to keep in the box), is unscrew the flat fitting and insert a nipple fitting and use the regular tip on the grease gun. When the joint is packed, swap the flat fitting back in. I already tried that and the only regular zert I have is a different thread size. I really don't mind buying a needle tip, I could use it to get to the u-joint on the drive shaft and a few on our Ford 8N. The hand held grease gun I have is a rigid neck, so that is no issue. Edit: I got a needle tip at autozone for $3, those things are gonna get greased all the time 8) Link to comment Share on other sites More sharing options...
