Thanks Limey Jeeper!
OffGridResearch
4 hours ago, pizzaman09 said:
Could you provide a link to this?  I'm tempted as our Comanches have very dim lights, and I'm down for anything that can reduce electrical current draw.
2 hours ago, Salvagedcircuit said:
Just to confirm, this part is designed to replace the 4 way flasher, and works well with led lights? If you can elaborate on what it does and it's benefits that would be great
Thanks.
Here is the link fellas. Long story short is This lets your Turn signal circuit communicate with modern LED bulbs. Like if you replaced your tail lights or turn signals with modern LEDs and you lose blinking functionality etc. Just yank out your old Yellow flasher from the Fuse panel under the dash. And Plug this one in and Ground the ground wire. Bam , instant communication. Integrated PCB board and ground circuit make it possible.
https://ogrshop.com/collections/lighting/products/xj-mj-led-flasher-fix-it-kit
  • 4 weeks later...
