Ωhm Posted March 11, 2024 Share Posted March 11, 2024 15 minutes ago, chance_p said: the light blue/black wire from the XJ harness is not connected to anything Doesn't that wire connect to the Brake Switch? Link to comment Share on other sites More sharing options...
chance_p Posted March 11, 2024 Author Share Posted March 11, 2024 5 minutes ago, Ωhm said: Doesn't that wire connect to the Brake Switch? Yes, it is switched power for brake lights. My confusion is that there is no dedicated brake light or 'stop' wire on the MJ. Just a LH turn/stop and a RH turn/stop. The XJ harness has LH turn, RH turn, and the separate stop wire (blue/white). I'm unsure of what to connect the blue/white wire to. Link to comment Share on other sites More sharing options...
Ωhm Posted March 11, 2024 Share Posted March 11, 2024 I think I see what you're saying. Cherokee (Amber Turn Signals) vs Wagoneer (Red Lens) show Cherokee going straight to the Stop Lamps and not through the Turn Signal Switch. So, my next question is what's in C156_P? Link to comment Share on other sites More sharing options...
chance_p Posted March 11, 2024 Author Share Posted March 11, 2024 *Pin 3 on XJ C118 connects to pin 5 on XJ C119. This will provide proper wiring for the brake lights I think this is the fix to my issue. Edit: confirmed. Jumping those two pins together makes the brake lights function. Link to comment Share on other sites More sharing options...
Ωhm Posted March 11, 2024 Share Posted March 11, 2024 Make sure Turn Signals work when Brake is applied. Link to comment Share on other sites More sharing options...
