@89 MJ -  You might get a laugh out of the way I painted this one.   I did it with Tremclad which is basically Canadian Rustoleum, single stage enamel.  I shot it outdoors in my backyard.   I has new fenders and a windshield frame plus the doors, tailgate and cowl were off when I did it.  The "good parts" have 4 coats with wet sanding in between.   I have a few small areas I want to go back at and then I might buff it out and polish it.   This is my main winter Jeep and that along with trail rides is going to beat it up a bit.   I wanted something I could easily touch up. hence the Tremclad. :L:
*P5 Seats - Cloth High-Back Bucket
-DV Dark Slate Gray
020 FAM: TJ TRACKING: 30714J06 MY:2004
028 FAM: TJ TRACKING: 30826J13 MY:2004
02U FAM: TJ TRACKING: 30603J04 MY:2004
03K FAM: TJ TRACKING: 31030J02 MY:2004
03N FAM: TJ TRACKING: 31001J09 MY:2004
03P FAM: TJ TRACKING: 40211J08 MY:2004
121 Zone 21-Canada-Ontario
1AB Canada Dealer Retail
24E Customer Preferred Package 24E
2TE Customer Preferred Package 2TE
4HB Special Scheduling Condition II
594 Vehicle Order Tracking
595 Long Wheel Base (LWB)
5I4 Four Wheel Drive (4WD)
5I8 Left Hand Drive (LHD)
5IS TJ-Vehicle Family
675 Ontario Province Code
6CS Label - Canada Specifications
6F2 Paint Order Code
A81 4.0L Eng (ERH)/4Spd A/T 42RLE (DG6)
AAS TIRE &&&& WHEEL GROUP - 30"
APA Monotone Paint
BAU Alternator - 117 Amp
BC2 Battery - 600 Amp Maintenance Free
BRW Brakes - 4-Wheel Disc
CAD Seats - High Back Bucket
CAG EASY ACCESS PASS TIP &&&& SLIDE SEAT
CDB Seats - Reclining Front
CFM Seat - Rear Folding
CGW Air Bags - Front, Next Generation**
CKE Carpet - Front Seat Area
CKF Carpet- Rear Seat/Wheelhouse/Cargo
CKT Cargo Tie Down Loops
CLC Floor Mats - Front
CLM Sport Bar - Full w/Padding
CUM FLOOR CONSOLE W/CUPHOLDER
DG6 Transmission-4-Spd. Automatic, 42RLE
DGB Transmission - 4-Speed Automatic
DHA Torque Converter - Lock-Up
DHN Command-Trac Part Time 4WD System
DJJ Axle - Front, Dana 30/186MM
DME Axle Ratio - 3.73
DRK HEAVY DUTY DANA 44 REAR AXLE
DSA TRAC-LOK DIFFERENTIAL REAR AXLE
ERH Engine - 4.0L Power Tech I-6
GBB Windshield Glass - Tinted
GCB LIGHT TINT FRONT DOOR WINDOWS
GCD Windows - Deep Tint Sunscreen
GCF Door - Full Metal w/Roll-up Windows
GNA Mirror - Rear View, Day/Night
GTV SWING-AWAY MIRRORS
GXX Sentry Key Theft Deterrent System
HCD HEATER W/INSTRUMENT PNL VENTILATION
JAY INSTRUMENT CLUSTER W/TACH
JDB Speedometer - 180 KPH Primary
JHA Windshield Wipers - Var Intermittent
JJF Horn - Single Low Note
JJJ Power Outlet - Auxiliary 12V
JKA Glove Box - Locking
K3X BLACK - FENDER FLARES
KER DARK SILVER MET. - BADGE - LWB
KWR DARK SILVER METALLIC - BADGE - JEEP,
LMA Headlamps - Halogen
LMK Daytime Running Lamps - Headlamps
LNJ Fog Lamps
LPS Lamp - Center Hi-Mount Stop
MB5 Bumper - Rear Black
MBA BLACK FRONT BUMPER
MCH BUMPER EXTENSIONS
MFP Headlamp Bezels - Chrome
MFR Front Frame Overlay - Black
MFT Grille - Body Color
MRJ Side Steps - Bodyside
MT2 Badge - Trail Rated
NAS Emissions - U.S. 50 State
NBG FEDERAL TIER 2, BIN 9A EMISSIONS
NBK EVAP Control System
NF1 Fuel Tank - 19 Gallon w/Tethered Cap
NHK Engine Block Heater
PSB Bright Silver Metallic Clear Coat
QSB Bright Silver Metallic Clear Coat
RAA All Radio Equipped Vehicles
RBK Radio-AM/FM Compact Disc w/Chgr Ctrl
RCD Speakers - Four w/Sound Bar
RDD Antenna - Fixed
SBA POWER STEERING
SCA Steering Wheel
SDU HIGH PRESSURE GAS CHARGED SHOCKS
SHA Stabilizer Bar - Front
SHC REAR STABILIZER BAR
SUA Steering Column - Tilt
TBB Spare Tire - Full Size
TBR Tire Carrier - Outside
TUS 30X9.50R15LTB WRANGLER OWL A/T TIRES
TZA Goodyear Brand Tires
VJX BLACK - Soft Top - Easy Folding
WJ4 15X8.0 "RAVINE" ALUMINUM WHEELS
WKB Wheel - Matching Spare
WLZ Wheels - All Aluminum
XCY UPGRADED OBD-II CONNECTORS
XEE Skid Plate Shield - Fuel Tank
XEF Skid Plate Shield - Transfer Case
XEW 2 FRONT &&&& 1 REAR TOW HOOKS
XJF Tethered Fuel Filler Cap
XLN Language - English/USA
XPF Protective Coating and Remover
YAC Build To Canada Market Specification
YGA Without Billable Fuel
Z5C GVW RATING - 4600#
ZAS Spring - Left Rear
ZBG Spring - Left Front
ZNS Spring - Right Rear
ZPG Spring - Right Front
Build date 3/17/4
Body code JH78
Sold by PORT ELGIN CHRYSLER DODGE JEEP, PORT ELGIN ON
Thanks @eaglescout526 :L:  This is a early LJ.   They were only available from 2004 to 2006 and according to many didn't go on sale until July of 2004.   No one is quite sure of the lead time but being built in March (St. Patrick's Day!) makes it an early one.   It was ordered without a hard top which is odd for Ontario.    The woman who bought it new didn't want to pay the price I guess.   Not having that option meant it also came without the electrical lines, switches, etc. or the plumbing for the rear window defroster or the wiper.   The washer bottle also has only one pump.
I had no idea what dealership this one was bought at.   By total coincidence I'll be camping 15 minutes from Port Elgin on Lake Huron in May.   I'll see if the dealership still exists.
