majastee508 Posted February 9, 2023 Share Posted February 9, 2023 Swapping from buckets with full length center console and want to find a mini console before starting the swap. Are the mini consoles interchangeable between auto and manual? Will the transmission shift indicator from the full length console work with the mini? Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted February 10, 2023 Share Posted February 10, 2023 As far as I know yes absolutely interchangable between manual and auto. Shift indicator will drop and lock right in. Link to comment Share on other sites More sharing options...
jpnjake Posted February 10, 2023 Share Posted February 10, 2023 3 hours ago, majastee508 said: Swapping from buckets with full length center console and want to find a mini console before starting the swap. Are the mini consoles interchangeable between auto and manual? Will the transmission shift indicator from the full length console work with the mini? Yes they are, the mini console’s are basically just a chopped down big console with everything in the same places Link to comment Share on other sites More sharing options...
majastee508 Posted February 10, 2023 Author Share Posted February 10, 2023 Thank you Link to comment Share on other sites More sharing options...
