Pete M Posted February 6 Share Posted February 6 part number checks out with what the manufacturer says it goes to, but those ports are definitely not in the exact same location (even thought hey are spaced apart from each other the same) and that interferes with the plastic on the hvac box. did I get a 97+ or something? Quote Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 6 Share Posted February 6 Not sure which one you got there. However, if your going to return it, get the plate and fin design vs the tube and fin. Four seasons makes a nice plate and fin that fits with slight mods. Done a couple now that way and it works great Quote Link to comment Share on other sites More sharing options...
AZJeff Posted February 7 Share Posted February 7 Where did you source that evaporator? ( It's not a 97+ XJ type, BTW.) Quote Link to comment Share on other sites More sharing options...
Pete M Posted February 7 Author Share Posted February 7 amazon. technically I didn't order it. but I did find it and send her the link. the overall size is good and the ports are good, just a bit off in location. Quote Link to comment Share on other sites More sharing options...
Pete M Posted February 7 Author Share Posted February 7 this one: https://www.amazon.com/Evaporator-Core-Compatible-Jeep/dp/B09S41YQ8Y Quote Link to comment Share on other sites More sharing options...
Pete M Posted February 7 Author Share Posted February 7 I'm probably just going to trim the plastic a bit. the tubes will fit out the firewall just fine and I was planning on replacing that gasket with a custom cut piece anyway. Quote Link to comment Share on other sites More sharing options...
ghetdjc320 Posted February 7 Share Posted February 7 1 hour ago, Pete M said: I'm probably just going to trim the plastic a bit. the tubes will fit out the firewall just fine and I was planning on replacing that gasket with a custom cut piece anyway. I have plenty of leftover oem gasket material if you’d like some. Quote Link to comment Share on other sites More sharing options...
Pete M Posted February 7 Author Share Posted February 7 hoping to just grab some at Hobby Lobby tomorrow. if I fail I'll let ya know. Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
