JZLAJeep Posted January 12, 2023 Share Posted January 12, 2023 Finally getting around to registering our Comanche. Tried to get the specs right. 1989 Jeep Comanche Pioneer long-bed 4.0 Renix, originally had Peugeot BA 10/5, Aisin AX-15 after transmission swap, NP231 transfer case, Dana axles, 119.9 inch long-bed wheelbase Build date: 2-89 Current Location: Ada County, Idaho Status: Back on the road after sitting for at least 5 years. Notes: Front and gas tank skid plates. Front bumper off of a 95 Cherokee. Rear bumper off of a 1st generation Dodge Dakota. Sliding rear glass window. Exterior color is white with Pioneer livery. Interior is dark blue with cloth bench seat. Manual transmission floor shift. What else… upgraded wiper arms from a 97+ Cherokee! Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2023 Share Posted January 14, 2023 *X1 -Q8 169 Zone 69-Phoenix 1AA U.S. Dealer Retail 4HC Special Scheduling Condition III 5AM Largo Tracking 5KN ADH HEAVY DUTY ELECTRICAL GROUP ADL SKID PLATE GROUP AHL HEAVY DUTY INSULATION GROUP ALN APA MONOTONE PAINT BA1 100 AMP ALTERNATOR BCY BATTERY, 58-475 CC BGA POWER FRONT DISC/REAR DRUM BRAKES BJA STD DUTY FRT DISC BRAKES BKP 10X2.5 REAR DRUM BRAKES CBA STRAIGHT BACK BENCH SEAT CKA CARPETS - FLOOR AND CARGO AREA CSR PASSENGER ASSIST HANDLE CUM MINI FLOOR CONSOLE DBB ALL MANUAL TRANSMISSIONS DDX 5-SPEED HD MANUAL TRANSMISSION DHN COMMAND-TRAC PART TIME 4WD SYSTEM DJH 230MM FRONT AXLE DMM 3.07 REAR AXLE RATIO DRJ DANA 35 REAR AXLE EAA ALL ENGINES EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC TINTED GLASS WINDOWS GBB TINTED WINDSHIELD GLASS GCB FRONT DOOR TINTED GLASS GEC FRONT LEFT SIDE SLIDING WINDOW GFD REAR SLIDING WINDOW GNA REAR VIEW DAY/NIGHT MIRROR GRZ LEFT REMOTE MIRROR GSZ RIGHT REMOTE CONTROL MIRROR GTZ MANUAL REMOTE MIRRORS HCD DO NOT USE - SEE HCA HGA HOOD INSULATION JAA INSTRUMENT PANEL JAY DO NOT USE - SEE JP, KA CLASSES JBD BEZEL-I/PANEL CLUSTER - BRIGHT JCA 85 MPH PRIMARY SPEEDOMETER JGB JHA VAR INTERMITTENT WINDSHIELD WIPERS JJA CIGAR LIGHTER JKB K2X STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KKE LAF SEAT BELT ALERT-DRIVER SEAT ONLY LAP SHIFT INDICATOR WARNING LAMP LBC GLOVE BOX LAMP LCJ DOME/READING LAMP B-PILLAR LMA HALOGEN HEADLAMPS MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG MHA Black Windshield Moldings MMC MMG Belt Moldings MMK NAF High Altitude Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PWB QWB RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TAE TBB Full Size Spare Tire TBM Tire Carrier Winch TMW Tires WJD 15X7.0 Styled Steel Wheels XBS Pickup Box XEE Fuel Tank Skid Plate Shield XEF Transfer Case Skid Plate Shield XEU Front Suspension Skid Plate XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 2/5/89 Body code JM62 Sold by RENO JEEP CHRYSLER, RENO NV Link to comment Share on other sites More sharing options...
Pete M Posted January 14, 2023 Share Posted January 14, 2023 Quote BEZEL-I/PANEL CLUSTER - BRIGHT ?? Link to comment Share on other sites More sharing options...
eaglescout526 Posted January 14, 2023 Share Posted January 14, 2023 1 hour ago, Pete M said: ?? Probably the chrome trim or the silver one. Link to comment Share on other sites More sharing options...
JZLAJeep Posted October 8, 2025 Author Share Posted October 8, 2025 Found the build sheet for this when we had the driver door panel off. Pretty cool! The page is stamped with a date 4 days earlier than the build date noted above. Link to comment Share on other sites More sharing options...
