1j4fj38l5ll266909
The86manche
28 minutes ago, The86manche said:
I don't know if it's cherokee or xj but it was a swapped door on a comanche I found in a yard. Maybe it was a comanche. It was dated 5-90
I'll move it to the "other" section and if it turns out to be an MJ I'll put it in the appropriate folder. :L:
*X7 CLOTH LOW-BACK BUCKET SEATS
-SA Charcoal
105 Zone 05-Chrysler Military Sales
1AV Export O.M.S.C. U.S. Specifications
3YJ Wheel and Tire Discount
4FV Assembly Plant Tracking
4HC Special Scheduling Condition III
8ED Miscellaneous Intl Dealers
APA MONOTONE PAINT
ARL 300 PREMIUM GROUP
BAQ 61 AMP ALTERNATOR
BCX Maint. Free Batteri
BGA POWER FRONT DISC/REAR DRUM BRAKES
CAC LOW BACK BUCKET SEATS
CDB RECLINING FRONT SEATS
CFM REAR FOLD W/REMOVABLE CUSHION SEAT
CKA CARPETS - FLOOR AND CARGO AREA
CKN CARGO COMPARTMENT CARPET
CKT CARGO TIE DOWN LOOPS
CSR PASSENGER ASSIST HANDLES
CUF FULL LENGTH FLOOR CONSOLE
DBB ALL MANUAL TRANSMISSIONS
DDQ 5-SPEED MANUAL TRANSMISSION
DHN COMMAND-TRAC PART TIME 4WD SYSTEM
DJH DANA M30/181MM FRONT AXLE
DMM 3.07 REAR AXLE RATIO
DRJ 175MM REAR AXLE
ERB ENGINE - 4.0L I6 MPI GAS
GBB TINTED WINDSHIELD GLASS
GCB FRONT DOOR TINTED GLASS
GED TINTED RR DRS/QTR/LIFTGATE GLASS
GEH FIXED DOOR VENT GLASS
GNA REAR VIEW DAY/NIGHT MIRROR
GNC SUN VISORS W/ILLUM VANITY MIRRORS
GRC ENTIRE FLEET KEY ALIKE (FREQ 7)
GUB POWER MIRRORS-BASE
HCD HEATER W/INSTRUMENT PNL VENTILATION
JAV DO NOT USE - SEE JP, KA CLASSES
JCA 85 MPH PRIMARY SPEEDOMETER
JGB
JHB REAR WINDOW WIPER/WASHER
JJA CIGAR LIGHTER
K3R FLAME RED CLEAR-COAT - FENDER FLARES
KKA STRIPE/BADGE/MOLDING/COLOR
LAJ HEADLAMPS ON WARNING CHIMES
LAP SHIFT INDICATOR WARNING LAMP
LBB COURTESY LAMPS
LBC GLOVE BOX LAMP
LBD ASH TRAY LAMP
LBE AMBIENT LIGHT
LCD MAP/DOME READING LAMPS
LDB CARGO COMPARTMENT LAMP
LDH U/HOOD, REMOVABLE/RECHARGEABLE LAMP
LHD HEADLAMP OFF TIME DELAY
LMA HALOGEN HEADLAMPS
MB2 Bright/Black Front Bumper
MB6 Bright/Black Rear Bumper
MDA Front License Plate Bracket
MFG Body Color Headlamp Bezels
MHB Bright Windshield Moldings
MMC Rear Qtr Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
MTA Rear Fascia Skid Plate Applique
MWA Roof Rack
NAA Federal Emissions
NBK EVAP Control System
NFA 20 Gallon Fuel Tank
PE4 COLORADO RED CC PRI PNT - HE4
QE4 COLORADO RED CC SEC PNT - HE4
RAA All Radio Equipped Vehicles
RAF AM/FM Cassette Radio
RCD 4 Speakers
SBA Power Steering
SCE Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBB Full Size Spare Tire
TBR Outside Tire Carrier
TPF P205/75R15 BSW All Season Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
YAA Build To U.S. Mkt. Specifications
YGA Without Billable Fuel
Z03 Rear Spring Group Iii
Z56 Left Front Spring Group Vi
Z5B GVW Rating - 4900#
Z76 Right Front Spring Group VI
Build date 5/22/90
Body code JL74 XJ
-SA Charcoal
APA MONOTONE PAINT
DRJ 175MM REAR AXLE
JGB
JJA CIGAR LIGHTER
LBB COURTESY LAMPS
LBC GLOVE BOX LAMP
LBD ASH TRAY LAMP
LBE AMBIENT LIGHT
MMG Belt Moldings
MWA Roof Rack
RCD 4 Speakers
SBA Power Steering
TAA All Tires
Build date 5/22/90
Body code JL74 XJ
As always, thanks eagle
