Bed bolts snapped off. How do I repair.
Do you have access to an oxy-acetylene torch? I'd heat the area around the stud, clamp on the threads with the biggest pair of vicegrips you can find and hope for the best. That's assuming you got something to bite to. Otherwise drill them out and retap to a larger size. Never had any luck using those stud extractors.
I'd also spray them down with Kroil or some other penetrating oil. Heat does good. Sort of expands and 'breaks' the rust hold. Still, many times, the rust is like it welds together.  Sometimes I can drill them through, then heat. I've had very limited success with the screw extractors. I have broken some and then that's a real problem. Sometimes I'll grind or use a carbide burr to 'section' the bolt, and break it apart. They did that to my wisdom teeth. Yeah, that was fun.
