Blazer25l0
Everything posted by Blazer25l0
  1. Ok. I see now. I have a new pump and sending unit ordered. Looking at the pics of it, it must be the rubber piece on the bottom of the return tube.
  2. Got a 88 comanche 18 gallong tank. Had to drop it to clean it out. Some debries from crumbling rubber around the fuel pump assembly. Notice this rubber grommet inside the tank, also crumbling. What is this grommet and where can I find a replacement.
  3. Yea I got the temp sensor already.
  4. What oil pressure sending unit do I for full gauge swap.
  5. Ok this makes things easy. Thanks for the help.
  6. Ok so got a 88 2wd comanche it is lifted. Not sure of the lift height but it's running 33" tires. Been rebuilding the comanche for about a year now. All the joints on the tie rod and drag link are no good. Are the steering components from the xjs interchangeable. Will 4wd linkage work on the 2wd. I'd really to to buy beefier linkage. Do any companies make and sell upgrade linkage for 2wd comanches. What are my options. Not sure what's interchangeable.
  7. Can anyone tell me all the types of screws that where used for the interior trim pieces on a comanche. Missing alot of scrws on a 88 comanche project. Just need to know what to order.
  8. What is the bolts size. What would be the next size up to drill out and retap?
  9. Taking the bed off my 88 short bed to repaint the truck.The 4 bolts sheared off. The 4 stud nuts came off no problem . How do I fix the sheared bolts in the bed.
