Salvagedcircuit Posted August 11, 2022 Posted August 11, 2022 I'm in the process of replacing all the rubber hoses and tubes that pull vacuum around the engine bay. I installed the Dorman 46003 & 46004 vacuum harnesses and I noticed two strangely shaped items hanging off the drivers side of my engine block. The Item circled in orange is supposed to connect to the item circled in purple. On close inspection, the item circled in purple is clogged full of crud and has likely died. What do these two items do? Thanks a ton!
fiatslug87 Posted August 11, 2022 Posted August 11, 2022 Purple is the EGR valve, orange is the EGR transducer.
Salvagedcircuit Posted August 12, 2022 Author Posted August 12, 2022 On 8/11/2022 at 1:14 AM, fiatslug87 said: Purple is the EGR valve, orange is the EGR transducer. Thank you greatly! I just grabbed some 5/32 line to replace the rotting vacuum line.
