Transfer case / Transmission swap
Hey,
I am swapping the transmission in my Comanche from the Peugeot the the Aisin. I purchased a transmission from a salvage dealer thinking that it was an ax-15, but it looks like it may be an ax-5. As I understand it, the ax-5 has 14/21 splines and the ax-15 has 10/23, and that the ax-5 was for 4 cylinders and the ax-15 was for 6 cylinders.
Is this correct? I've been using car-part.com to find parts, and these are the listing choices for transfer cases:
899227502_Screenshot2022-06-29at20-34-03SearchResults.png.dc7788f8e01a6ad1faa596e80ea88441.png
If this is right, does that mean that there were two Aisin transmissions for the 6.0 4x4 that had different numbers of splines?
4bangers were always 21 spline.  the peugeot was always 21 spline.  the AX-15 was always 23 spline.  the AW4 was 21 spline 87-90 and then 23 spline after that.  :L:
if the AX-15 started out as 21 spline output, I'm going to need some hard evidence to believe it.  :dunno:
Ok, new info....
I counted the splines on my transmission, and it has 10 and 21. I also looked up the serial number, and it looks like I was sold a Peugeot and not an Aisin (53005252).
This being the case, should I just swap in the Peugeot? I was going to swap everything (bellhousing, mounts, transfer case, etc), but if I already have the transmission it would save me money and time to just throw it in... on the other hand, I know the Peugeots weren't the best transmissions. Will I regret not going with the ax-15?
if they sold that as an AX-15, I'd go get my money back.
but yes, you can swap it in too. :L:  fingers crossed that it's not bad.  just don't waste any money rebuilding a peugeot.
