1JTHW6418JT239768
Hipline
2.5 litre
5 speed 2wd
not currently safetied but want to have it done for a daily driver.
Wanting to do a 4x4 swap.
cold air intake
Aftermarket temp gauge
oil pressure gauge.
rpm gauge
200k km
Known issues
brakes don't work
breather falls off
rust in rockers, cab corners, box sides, and front fenders
Exhaust is there but needs to be re attached at rusted off point
leaks rain in the cab from as of now unknown issues
passenger door handle button is gone so you can only open it from the inside. Passenger door window crank doesn’t work either. Driver side grinds
runs and drives great.I Will definitely be driving this one for a long time. Will also restore bit by bit. I can do everything myself aswell. Gonna be a fun project.
my goal is to keep the 2.5l manual and get the 4x4 swap for winter reasons. Let me know any ideas and money saving tricks you got.
Edited by Hipline
Missing serial numbers/ added info and pics
  • Hipline changed the title to 1JTHW6418JT239768
*X3
-SA Charcoal
ADE COLD WEATHER GROUP
AGC
APA MONOTONE PAINT PACKAGE
BCQ Battery - 750 Amp Maintenance Free
CBA BENCH SEAT - STRAIGHT BK
CGX Head Restraints-Outboard Seating, RR
DDJ 5SPD MANUAL TRANS
EPD ENGINE - 2.5L I4 TBI GAS
GAC ALL WINDOWS - TINTED GLASS
JDA SPEEDOMETER - 140 KILO PRIMARY
JJA CIGAR LIGHTER - FRT COMP
KQJ
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
MDA FRT LICENSE PLATE ATTACH REQUIRED
NAG
PE4 Colorado Red
QE4 Colorado Red
RAC RADIO - AM/MTR
TBG SPARE TIRE - COMPACT
WMC BASE WHEEL DRESS - UP (INCLS TRIM RING)
Build date 6/28/88
Body codeTL61
Sold by HUNT MOTORS, SWAN RIVER MB
2 hours ago, Hipline said:
Thank you eaglescout526!!!
apologies on behalf of AMC for the shortness of the printout.  a lot of info was lost in an apparent flood of the records room of AMC (that's the story we've heard) and so didn't get into the Chrysler computers. :(  your full build sheet is much longer.  if you sneak a peak at the later years of MJs, you'll get an idea of what I'm talking about.  Eventually we hope to piece together all the missing bits. :L:
