Fuel help
In need of help quick. My truck was just priming and running now it won't. Occasionally it will just start priming and not stopping but only with one relay I switch it out too. I cut the ground at the pump and grounded it closes and it still doing the same thing. Also my fuel pump gauge is way above full. What could be wrong?
Also My fuel rail was just leaking before this if that could have anything to do with it.
15 hours ago, eaglescout526 said:
Man. Much ain’t goin your way right now. Has everything been cleaned? Like contacts, C101, fuse block connector?
I cleaned all the relays out and most connectors when I put them in. Haven't tried c101 yet.
Yeah i will do that. I belive my ign might be bad though. No tach anymore and I belive ecu makes tank prime so it could make sense that it's bad. Also my rem gets no power now and the diagnostic port is powered by the ign
