Manche Man Posted May 19, 2022 Posted May 19, 2022 Hello everyone, I'm newer to the forum but have used many of your threads as some solid guides to help out with my comanches. I have seen many threads about this topic before, but none of them cover exactly what I need or want. With that being said, as the title states, my 4WD is not engaging.. Took it to the dunes the other day and noticed that the T-Case would engage but not the front axle. I narrowed it down to the shift fork not locking the axle into 4wd. I have seen many videos and tutorials/guides on how to do a CAD delete and just manually lock it in so it never fails again, but I have been told this also engages the running gear and will cause more friction and wear down the road (not to mention take my MPG down a notch or two). So, I'm guessing its the vacuum lines that aren't working, but I'm having a hard time finding where the lines go from the front axle. Anyone have any ideas where I might be having a leak/where the lines are going to? Also, the jeep overheats when I put into 4 Low and drive it for a bit... And before I forget, I have three 1988 jeep comanches, all 5 speed manuals, all 4.0 inline 6's, all relatively stock (bought them all used). The one I'm working on is a 1988 jeep comanche base model, 4.0, 5spd, AC/Heat, NP231 Command Trac transfer case, 153k miles. Thanks guys.
jdog Posted May 19, 2022 Posted May 19, 2022 My bet is the connector at the axle, and 95% of the responses are going to be lock it in, Chrysler did in the 90s and it doesn't affect mpg but a smidgen the only thing it will engage is the front drive shaft. If you really want to keep it a vacuum operating, the lines go to the tcase and then to the firewall
Manche Man Posted May 19, 2022 Author Posted May 19, 2022 51 minutes ago, jdog said: My bet is the connector at the axle, and 95% of the responses are going to be lock it in, Chrysler did in the 90s and it doesn't affect mpg but a smidgen the only thing it will engage is the front drive shaft. If you really want to keep it a vacuum operating, the lines go to the tcase and then to the firewall Alright. So Chrysler did lock that front driveshaft eventually? Or did they find another method to engage/disengage it? And do you know where those lines into the firewall go? Can I get to any if I pull my dash apart? Thanks again.
jdog Posted May 19, 2022 Posted May 19, 2022 Yes they went with a one piece axle shaft, iirc they go to the Vacuum ball in the bumper
Manche Man Posted May 19, 2022 Author Posted May 19, 2022 Alright. Sounds good. I'll whip out the butane torch and see if I can find a vacuum leak somewhere. I'll come back to this thread if I can't find it or have some trouble doing the CAD delete (shouldn't be a worry) Thanks!
Pete M Posted May 19, 2022 Posted May 19, 2022 the link in my signature has a couple ways to lock it for good. :)
Manche Man Posted May 19, 2022 Author Posted May 19, 2022 Alright! thanks! Probably will do the delete if I can't nail down those lines
