1989 Jeep Comanche
4.0 AW4 242 Dana 30 Chrysler 8.25 SWB
Status: On the road and driven on the weekend trips to Lowes or hauling things to the dump. Does get beat on from time to time
*E1 Cloth Bench Seat
-SA Charcoal
166 Zone 66-Orlando
1AA U.S. Dealer Retail
5AM Largo Tracking
5KN
ALN
APA Monotone Paint
BAY 105 Amp Alternator
BCY BATTERY, 58-475 CC
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHT Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ Dana 35 Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEC Front Left Side Sliding Window
GFD Rear Sliding Window
GNA Rear View Day/Night Mirror
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HAA Air Conditioning
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBD BEZEL-I/PANEL CLUSTER - BRIGHT
JCA 85 MPH Primary Speedometer
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
JKB
K2X STRIPE/BADGE/MOLDING/COLOR
K3E STRIPE/BADGE/MOLDING/COLOR
KKE
LAF Seat Belt Alert-Driver Seat only
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Bumper
MFG Body Color Headlamp Bezels
MHA Black Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMK Grille
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PE8
QE8
RAA All Radio Equipped Vehicles
RAB AM/FM Radio
RCD 4 Speakers
SBA Power Steering
SCE Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TAA All Tires
TAE
TBC Compact Spare Tire
TBM Tire Carrier Winch
TMW Tires
WJD 15X7.0 Styled Steel Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z59 Left Front Spring Group Ix
Z78 Right Front Spring Group VIII
Build date 6/21/89
Body code TM61
Sold by COURTESY CHRY-JEEP OF CASSELBERRY, CASSELBERRY FL
9 minutes ago, MJ_Corrry said:
Thanks for the information!
whoops, you saw it before I was able to get here and edit out the reused codes (the codes are right, but the letters now refer to more modern chrysler stuff).  sorry, but the truck didn't come with a powder coated bumper of rack-n-pinion steering or an electric t-case.  :L:
Majority of what it came with is long gone by now anyways :laugh:, I know the manufactures reuse RPO codes (thats what GM calls them) The Vivid Red could work now though. Awesome to be able to gather all this info still.
being an 89, if you find the thread that has the code explanations on the back of an 89 build sheet, you miiiiiight be able to fill in some blanks.  but as you said, she's most definitely grown past the stock stage anyways. :D
