schardein Posted January 29, 2022 Posted January 29, 2022 This connector is from a 93 ZJ, it is the same as a 1991-92 MJ tail light harness connector. You can use this to make your own trailer wiring harness without having to cut into the factory MJ harness. The ZJ uses a different pinout. I have moved the wires to create the correct pinout for an MJ, although the wire colors won't be a match to the MJ harness. $20 shipped from Success, MO 65570.
500 MJ Posted January 29, 2022 Posted January 29, 2022 Curious where the connector is located on the ‘93 ZJ? Does it serve for the rear tail lights as well?
schardein Posted January 31, 2022 Author Posted January 31, 2022 On 1/29/2022 at 1:04 PM, 500 MJ said: Curious where the connector is located on the ‘93 ZJ? Does it serve for the rear tail lights as well? Yes. Tail light harness connector located driver side rear, under the body. Pin out is different, one wire needs to be moved to match the MJ pin out. My research shows some 94 GC may have it also. I haven't verified this on the truck, but according to the FSM, this is the MJ tail light pinout. As I mentioned above, the GC wire colors are different.
ExpatMJGuy Posted February 6, 2022 Posted February 6, 2022 Wasn't this the connector someone used to make a trailer light harness?
schardein Posted February 6, 2022 Author Posted February 6, 2022 3 hours ago, ExpatMJGuy said: Wasn't this the connector someone used to make a trailer light harness? This connector is for 91-92 trucks. To my knowledge, no one is currently offering a pre-made one based off this part, yet. The 1987-1990 connector is different, can be found on some models of Cadillacs in the engine compartment, and is offered pre-made by a member here (or was at one time, and may have been offered by more than one?) 1986 uses a different connector as well.
Archived
