Aussiemj Posted December 30, 2021 Share Posted December 30, 2021 Hi everyone my 1990 4 litre 5 speed has a broken transmission lug mount . Can I use rear case from a yj or does have to be xj/Mj part thanks paul Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 30, 2021 Share Posted December 30, 2021 Not sure what you talking about. Pic be easier as then I could read it better. What trans do you have ax 15 or ba-10? Link to comment Share on other sites More sharing options...
Aussiemj Posted December 30, 2021 Author Share Posted December 30, 2021 I have a ax15 Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 30, 2021 Share Posted December 30, 2021 Ok. I wanna say weld it back. But in theory you should be able to swap the case with any 4wd ax 15 as the internals shall stay the same. Link to comment Share on other sites More sharing options...
MiNi Beast Posted December 30, 2021 Share Posted December 30, 2021 Just now, MiNi Beast said: Ok. I wanna say weld it back. But in theory you should be able to swap the case with any 4wd ax 15 as the internals shall stay the same. Futhermore a yj ax 15 should be a direct swap. I think it was just the tcase that was clocked different an xj/mj setup. Link to comment Share on other sites More sharing options...
Aussiemj Posted December 30, 2021 Author Share Posted December 30, 2021 I would weld but part is to damaged plus being alloy Link to comment Share on other sites More sharing options...
Eagle Posted January 3, 2022 Share Posted January 3, 2022 On 12/29/2021 at 10:37 PM, Aussiemj said: I would weld but part is to damaged plus being alloy Aluminum can be welded by TIG. I would certainly try that before hunting down a blown tranny and taking two of them apart nto move the rear housing over to yours. Link to comment Share on other sites More sharing options...
AZJeff Posted January 3, 2022 Share Posted January 3, 2022 30 minutes ago, Eagle said: Aluminum can be welded by TIG. I would certainly try that before hunting down a blown tranny and taking two of them apart nto move the rear housing over to yours. I agree. Any competent welding shop can repair a broken aluminum casting with the appropriate welding method and filler. The cost would probably be less than the cost of a used transmission for a case donor. Link to comment Share on other sites More sharing options...
