m2bandit Posted November 29, 2021 Posted November 29, 2021 Previous owner cut the exhaust off behind the cat. I'm looking to put a flowmaster on with the walker tailpipe. I can weld but no bender so I need it to fit. It looks like it should be center in but flowmasters are a bit bulky.
JMO413 Posted November 30, 2021 Posted November 30, 2021 This is my set up with a Thrush muffler and a pice of flex pipe where the cat would normally be. Center in with an offset out.
m2bandit Posted November 30, 2021 Author Posted November 30, 2021 6 minutes ago, JMO413 said: This is my set up with a Thrush muffler and a pice of flex pipe where the cat would normally be. Center in with an offset out. How do you like the thrush sound?
JMO413 Posted November 30, 2021 Posted November 30, 2021 https://youtube.com/shorts/7h5WhgSCmRk?feature=share Love it!
m2bandit Posted November 30, 2021 Author Posted November 30, 2021 3 minutes ago, JMO413 said: https://youtube.com/shorts/7h5WhgSCmRk?feature=share Love it! Thank you sir, I went with the thrush.
JMO413 Posted November 30, 2021 Posted November 30, 2021 I will be putting on on my XJ for sure. Sounds great and affordable to boot.
89 MJ Posted November 30, 2021 Posted November 30, 2021 I went with the Walker setup from RA for my MJ. It’s quiet, but has a good sound.
JMO413 Posted November 30, 2021 Posted November 30, 2021 Mine is the Walker down pipe and Walker tail pipe both fit nicely.
