I managed to pick up an Aluminum Valve cover from a 90s YJ but I've noticed that the air inlet looks like it takes a twist-on fitting. It's different from some of the others I've seen on here that take a regular grommet.
The only elbow fittings I'm finding that twist on like this are all labeled as being for the 4.0.  Also, I can't find any threads on here that go over how to convert the PCV and Breather over to work with these.
Any help is appreciated.
Iirc using the breather hoses from the 97 2.5  xj will work. Possibly the 96 and older too .
I’d have to check, and I don’t know when I’m gonna be home next. But I may have a valve cover with those hoses on it.
20 hours ago, eaglescout526 said:
They are discontinued but it looks like a dealer in my state has one.
Thanks for checking. I can get the dorman version from Oreilly's if needed. They have them in stock.  Being such a trivial part, I'm sure I can get some miles out of it.
Thanks a lot. I think I found an elbow that will work with my existing hoses. I will probably try it but I need to clean and reassemble my cover first.
