jamcomanche Posted November 15, 2021 Share Posted November 15, 2021 I managed to pick up an Aluminum Valve cover from a 90s YJ but I've noticed that the air inlet looks like it takes a twist-on fitting. It's different from some of the others I've seen on here that take a regular grommet. The only elbow fittings I'm finding that twist on like this are all labeled as being for the 4.0. Also, I can't find any threads on here that go over how to convert the PCV and Breather over to work with these. Any help is appreciated. Link to comment Share on other sites More sharing options...
jamcomanche Posted November 15, 2021 Author Share Posted November 15, 2021 I think I found it. Interchange Part Number: 53030591, DOR47056, 630-1093, 47056 @eaglescout526 these aren't mopar part numbers, but are they enough to help you find one? Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 15, 2021 Share Posted November 15, 2021 15 minutes ago, jamcomanche said: 53030591 This one is. Let me see what’s out there. Link to comment Share on other sites More sharing options...
eaglescout526 Posted November 15, 2021 Share Posted November 15, 2021 They are discontinued but it looks like a dealer in my state has one. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted November 15, 2021 Share Posted November 15, 2021 Iirc using the breather hoses from the 97 2.5 xj will work. Possibly the 96 and older too . I’d have to check, and I don’t know when I’m gonna be home next. But I may have a valve cover with those hoses on it. Link to comment Share on other sites More sharing options...
jamcomanche Posted November 16, 2021 Author Share Posted November 16, 2021 20 hours ago, eaglescout526 said: They are discontinued but it looks like a dealer in my state has one. Thanks for checking. I can get the dorman version from Oreilly's if needed. They have them in stock. Being such a trivial part, I'm sure I can get some miles out of it. 19 hours ago, Strokermjcomanche said: Iirc using the breather hoses from the 97 2.5 xj will work. Possibly the 96 and older too . I’d have to check, and I don’t know when I’m gonna be home next. But I may have a valve cover with those hoses on it. Thanks a lot. I think I found an elbow that will work with my existing hoses. I will probably try it but I need to clean and reassemble my cover first. Link to comment Share on other sites More sharing options...
