Posted (edited)
1987 Jeep Comanche Laredo, 101,500 original miles
4.0, AW4, NP231, D30, D44 (3.73), LWB
https://ibb.co/wMfymhw
https://ibb.co/rd6v1n7
https://ibb.co/ZN9n431
https://ibb.co/y48pCGz
No Build date sticker, must have been removed
Located in Norfolk VA, came from Greenville NC (made 160 mile drive home under its own power)
Running and barely driving, about to start restoring!
This jeep is loaded, basically has every option I have seen them able to come with exception of the "metric ton" leaf springs. Truck is largely complete with absolutely no rust, has factory Tcase skid plate, but is missing the original tow hitch and doors with tow mirrors. PO swapped 97-01 power doors on. 4.0 has factory cooling system with pressure bottle, and a few added mechanical gauges like oil pressure and temp sensor. Interior is in mint condition with a new carpet and headliner, currently the interior trim is disassembled in boxes while I address some leaks in the rear windshield. In the glovebox, I found the original 4x4 Comanche manual with the original owners purchase information. Has honey bucket seats with a center console, and all of the original interior lights, twilight relay (Laredo option?) and cargo light are all functioning. Has original fog lamps (with uncracked covers, not currently working but getting power via wiring harness). Trans power comfort switch is functional. Shift column needs some help, High beams don't currently work, and cruise control/wiper settings don't work on all settings. Motor is weak and has low oil pressure via mechanical gauge, lifter noise on startup is pretty bad. Still runs and drives though!  planning on doing a full rebuild with some engine/electrical modifications (C101 is already deleted,Cruiser54 tips have been started). Not going to build it to be a wheeler, planning on doing a mild 1-2 inch lift and revamp of suspension to make a comfortable daily driver.
Currently owned by tman.ossi in Norfolk, Virginia
Edited by tman.ossi
remove name, just in case
*W7 Cloth Bckt Seats
-YY
3LY
ADA LIGHT PACKAGE
ADL SKID PLATE GROUP
AGL
AHL HEAVY DUTY INSUL PACKAGE
APA MONOTONE PAINT PACKAGE
AWH POWER EQUIPMENT GROUP
BCQ Maintenance Free Battery
CAC BUCKET SEAT
CGW
CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ
CLE ACCESSORY FLOOR MAT - FRONT &&&&&&&& REAR
CUF FULL LENGTH FRONT CONSOLE
DGQ TRANSMISSION-4SPD AUTOMATIC
DMR 3.55 Axle Ratio
DSA LIMITED SLIP DIFFERENTIAL
ERB ENGINE - 4.0L I6 MPI GAS
GAC ALL WINDOWS - TINTED GLASS
GEC Window - Left Side, Front, Sliding
GFD SLIDING RR WINDOW
GSC MIRROR - RIGHT BLACK
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JFH TACHOMETER - MECH
JGB Clock - Digital
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
K60 BODY SIDE MLDGS - VINYL
LBB COURTESY LAMPS (BELOW PANEL)
LDA UNDERHOOD COMPT LAMP
LMA HALOGEN HEADLAMPS
LNJ Fog Lamps
LPE EXTERIOR CARGO LIGHT
MBF REAR BUMPER - STEP TYPE (BRIGHT)
MCA FRONT BUMPER GUARDS
MCB
MDA FRT LICENSE PLATE ATTACH REQUIRED
MFD BRIGHT GRILLE - TYPE I
MWF BOX SIDE RAILS
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 23 GAL FUEL
NHM AUTO SPEED CONTROL
PE4 Colorado Red
QE4 Colorado Red
RAF Radio - AM/FM Cassette
SBA POWER STEERING
SCE STRG WHL - EURO/SPORT TYPE
SUA TILT STEERING COLUMN
TBB CONVENTIONAL SPARE TIRE
TBL TIRE CARRIER - INSIDE
WJN 15" Aluminum Wheels
XEA TOW HOOKS
Build date 10/7/86
Body code JP62
Sold by ALAN HYATT JEEP-EAGLE, SMITHFIELD NC
