BentGear Posted October 28, 2021 Share Posted October 28, 2021 My truck is lifted and the rear driveshaft is too short. There are two options I am considering right now, although I am open to other ideas. I would like to hear what you all think I should do. Option 1: ~$150 Have the existing drive shaft lengthened by my local driveshaft shop Option 2: ~&750 Order a Slip Yoke Eliminator and custom driveshaft from Oliver driveshafts I have been thinking one day I might install a Dana 44 in the rear which might then need a different length driveshaft, in which case maybe I am better off just to lengthen the current one. Thoughts? Link to comment Share on other sites More sharing options...
Pete M Posted October 28, 2021 Share Posted October 28, 2021 does "lengthened" mean a whole new shaft body? if so, I'd probably do that. but if you've got the cash, the SYE is a good strength upgrade. Link to comment Share on other sites More sharing options...
Jesse J Posted October 28, 2021 Share Posted October 28, 2021 the shop I went to charged me 45 for the shaft 45 for mount and balance and 60 for U joints. What it looks like he did was chopped the ends off and just welded a new tube in. works great for me going to need to take both shafts back when I run dual tcases. Since its an lwb shaft I really have no use for a SYE other than strength or whatever Link to comment Share on other sites More sharing options...
Eagle Posted October 29, 2021 Share Posted October 29, 2021 How much additional length do you need? If you are going to be changing the rear axle in the future, I would spend as little as possible now. If you only need an inch or so, the front yoke from a YJ rear driveshaft is supposed to be enough longer than an XJ/MJ yoke to make up that difference. That's probably cheaper than having a driveshaft custom modified. Link to comment Share on other sites More sharing options...
BentGear Posted November 14, 2021 Author Share Posted November 14, 2021 ***UPDATE*** So I had my driveshaft extended, it cost a little more ($300) because they also replaced the u-joints. But I wanted to mention the truck runs unbelievably better, even the shifting is smoother. The engine used to bog down a little under 2k rpm. Now it runs strong, it's like a new vehicle, all from a driveshaft. Money well spent. Link to comment Share on other sites More sharing options...
Pete M Posted November 14, 2021 Share Posted November 14, 2021 Link to comment Share on other sites More sharing options...
