Thandraux Posted October 4, 2021 Posted October 4, 2021 1989, Jeep, Comanche (Base I believe). Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase: No Clue Unfortunately but I do know that I have been buying parts for the 1989 Jeep Comanche with O' Reilly's and Rock Auto and so far everything has fit so: Inline 6 Cylinder 4.0L, believe original Manual Transmission, no clue on everything else. Build date: (its on the driverside door sticker, in the form of month and year): So this is all been rubbed off over the years. Current Location: Minnesota Status: Is it still on the road: It is on the road, currently my daily driver. Notes: Bought from a Used care dealer in Montrose, CO back in 2013, and have had it ever since, still figuring out what all they did to it, but do know that there is a body/lift kit on it by 3" and started doing upgraded parts when something breaks down on it. Current owner: Me
Pete M Posted October 5, 2021 Posted October 5, 2021 nice truck! @Thandraux if you can provide your VIN, we can look it up at Chrysler and give you a bunch more info on it.
eaglescout526 Posted October 5, 2021 Posted October 5, 2021 Yeah, a VIN would be nice. Then I can get you all the info about your truck that still remains in the Chrysler database.
Thandraux Posted October 5, 2021 Author Posted October 5, 2021 VIN Number as follows: 1J7FJ26L8KL459084
eaglescout526 Posted October 5, 2021 Posted October 5, 2021 *X2 TRIM STYLE X2 - VINYL BENCH -Q8 174 Zone 74-Denver 1AA U.S. Dealer Retail 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed HD Manual Transmission DHN Command-Trac Part Time 4WD System DJH 230MM Front Axle DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KDB STRIPE/BADGE/MOLDING LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAF High Altitude Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF2 18.5 Gallon Fuel Tank PB3 QB3 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA Audio SBA SCB steering wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC Tires WJK 15X6.0 Styled Steel Wheels WMC Bright Wheel Trim Rings XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z65 Left Front Group XIV Z84 Right Front Spring Group XIII Build date 10/24/88 Body code JL61 Sold by AUTONATION CHRYSLER JEEP WEST, GOLDEN CO
Thandraux Posted October 5, 2021 Author Posted October 5, 2021 Holy smokes, that is a lot more detail than I have ever been able to pull up on Bluebird! Thank you so much, this should help in the search for newer replacements or even upgrades.
Pete M Posted October 5, 2021 Posted October 5, 2021 12 minutes ago, Thandraux said: Holy smokes, that is a lot more detail than I have ever been able to pull up on Bluebird! Thank you so much, this should help in the search for newer replacements or even upgrades. most importantly, her 33rd birthday is coming up soon.
Buffalo Man Posted Friday at 02:18 PM Posted Friday at 02:18 PM Thanks for your help organizing! Mine is a 1989 4.0 5 speed 4wd. Short Bed Laredo, I believe. 1J7FJ26L8KL459084 It has been painted a darker blue, and the bed is rhino lined. It had 220000 miles on it when the Odometer stopped in Feb 2026. I aim to fix that. It has the BA10/5 and 3.07 gears and a 3" lift. Located in Athens, Ohio I'd like to upgrade the axles, transmission & leave it stock otherwise. It's a beautiful truck and I have waited my whole life for this. LOL It will stay with me until one of us dies completely.
