BlackComanche89 Posted August 30, 2021 Share Posted August 30, 2021 (edited) Now the government in Sweden has forced us to only use e10 gas (95) how is it for a renix? Any risk för damages? 98 is still a option even if more expensive for the moment 2 dollar / litre and för sure more expensive soon.. Edited August 30, 2021 by BlackComanche89 Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 30, 2021 Share Posted August 30, 2021 Somewhere but not entirely conclusive results is reports saying Renix runs better with the higher ethanol gas. I can believe that as it would probably pulse less gas into the chambers but who knows for sure. Otherwise Renix will run fine with the higher stuff. Hell you could probably feed it Russian vodka and it wouldn’t know(please don’t do that). Link to comment Share on other sites More sharing options...
omega_rugal Posted August 31, 2021 Share Posted August 31, 2021 it works fine, most engines can run up to E10 without modifications, some can even go as high as E15, but higher requires a flex fuel ready engine... you main concern would be rust inside the fuel lines Link to comment Share on other sites More sharing options...
cruiser54 Posted August 31, 2021 Share Posted August 31, 2021 It will run fine. The fuel lines go to $#!& though. Link to comment Share on other sites More sharing options...
BlackComanche89 Posted August 31, 2021 Author Share Posted August 31, 2021 20 minutes ago, cruiser54 said: It will run fine. The fuel lines go to $#!& though. Rust you mean? Link to comment Share on other sites More sharing options...
cruiser54 Posted August 31, 2021 Share Posted August 31, 2021 Not to the hoses. The hoses get soft on the inside and stiff on the outside. The worst one is the one in the fuel tank. From the pump up to the mounting flange. It gets all soggy and can collapse and split. Link to comment Share on other sites More sharing options...
