AW4 transmission price quote
Hey guys! So I’m looking to put a new or factory remanufactured Aw4 onto my build (I6 out of a 1995 Cherokee swap) in order to further my progress on this project. Problem is I can’t find anything close to new (obvious given it’s not 1995 anymore )or even remanufactured. The only luck I seem to have is people trying to sell me ones with over 120k miles on it and I’m not into that. I called a place that will fully build it with a harness, fluid, TC, and fresh paint but they want about $2600!! Can anyone guide me to somewhere they’re a bit cheaper maybe? Any help would be appreciated
That is cheap.
Further, I would never invest in an AW4 but if I had to there is no other shop that would touch it but this one-
And people from all over the country go to him.
59 minutes ago, Jeep Driver said:
That is cheap.
I really am new to this comanche restoring thing:/. Appreciate the help forsure. If you think that’s a decent price I will consider it. And I will definitely be looking into this guy. Where about in Cali is he?
Also is yours swapped with a different engine or did you use an adapter plate to mount a different trans on yours??
 Not sure where you're located, but I would check car part, they have quite a few transmissions with roughly 60,000 miles on them. May be worth it if it's close to you, or shipping.  I believe anything up to a 97 should work for you. The 97 will need a plug change, hopefully that'll help you expand your search. 87 through 90 will be at 21 spline(  so you would have to change the input gear or Tcase also ) so you want to stick with 91 to 97
 I had the AW4 transmission rebuilt in my black truck, cost me $900. There was an option for a shift kit, which was about $200 more . Going on eight years, with zero issues .
