Far McKon Posted August 17, 2021 Share Posted August 17, 2021 Stone White Automatic I6, with a 4x4 option Long-bed (whoo!) 220K + (odometer broke) Has a aftermarket Dodge Dakota bumper Has a different VIN # on the door, seems the door was replaced once upon a time. Bought for ~10K in 2021 Link to comment Share on other sites More sharing options...
jdog Posted August 17, 2021 Share Posted August 17, 2021 Don't you mean I6? Or did they swap a v6 in Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 18, 2021 Share Posted August 18, 2021 *X2 -H9 AGC APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT DGQ TRANSMISSION-4SPD AUTOMATIC ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GSC MIRROR - RIGHT BLACK JAY Instrument Cluster w/Tach JDA SPEEDOMETER - 140 KILO PRIMARY JGB Clock - Digital JJA CIGAR LIGHTER - FRT COMP KD8 DELETE TAPE STRIPE COLOR SEPARATION KQJ LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED NAG PS4 BRIGHT PLATINUM METALLIC CLEAR COAT QS4 BRIGHT PLATINUM CLEAR COAT SBA POWER STEERING TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) Build date 11/17/87 Body code JL61 Sold by JACK EASTON JEEP EAGLE, VINELAND STATION ONTARIO CANADA. Link to comment Share on other sites More sharing options...
Far McKon Posted August 19, 2021 Author Share Posted August 19, 2021 @eaglescout526 Amazing overview. The truck clearly has been rebuilt/repaired a lot since then, great to know how it came off the factory floor. @jdog Fixed it to I6. Somehow when I was thinking '6 cylinder ' my hands just type `V`, even though I know better Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 19, 2021 Share Posted August 19, 2021 @eaglescout526 is the Body Code correct? This is a LWB but the code is 61. @Far McKon what is the VIN on the door? The VIN you listed says this is a 4 Speed Automatic Floor Shift (R in pos#5) SWB (3 in pos#7). Also, do you see any evidence of the "original" color anywhere? Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 19, 2021 Share Posted August 19, 2021 9 minutes ago, fiatslug87 said: @eaglescout526 is the Body Code correct? This is a LWB but the code is 61. Yup! Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 28, 2021 Share Posted August 28, 2021 @Far McKon what is the VIN on the door? The VIN you listed says this is a Automatic Floor Shift (R in pos#5) SWB (3 in pos#7). Also, do you see any evidence of the "original" color anywhere? Thanks, just trying to clear this up for the Registry spreadsheet. Link to comment Share on other sites More sharing options...
Far McKon Posted August 30, 2021 Author Share Posted August 30, 2021 @fiatslug87 Door VIN is "1J7FJ 26L9K L6166 23" . I don't see sign of original paint job, but I dig the white IT does need a bunch of scratch touch-up though. It is an automatic, with 4-wheel "shifter" in the floor, is that what "Automatic Floor Shift (pos#5)" means? I'll double check the VIN number. It was a sunny day when I setup insurance, and only had the front window vin. Maybe I got it wrong? Link to comment Share on other sites More sharing options...
jdog Posted August 30, 2021 Share Posted August 30, 2021 Vin for the door is a 89 Comanche body code jl62 Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 30, 2021 Share Posted August 30, 2021 @jdog can you please run the 1J7FJ26L9KL616623 VIN The JL62 body code describes this truck as LWB which from the picture it is. I wonder if the dash was replaced but the VIN tag was not replaced. Link to comment Share on other sites More sharing options...
jdog Posted August 30, 2021 Share Posted August 30, 2021 Yep after lunch I'll grab the rest Link to comment Share on other sites More sharing options...
jdog Posted August 30, 2021 Share Posted August 30, 2021 Body: jl62 Build: 5/20/89 Selling Dealer: HALTERMAN'S AUTO RANCH EAST STROUDSBURG, PA APAS Monotone Paint BGAS Power Front Disc/Rear Drum Brakes BJAS DESCRIPTION NOT AVAILABLE BKPS 10x2.5 Rear Drum Brakes CSRS Passenger Assist Handles DGSS 4-Speed Automatic AW4 Transmission DHAS Lock-Up Torque Converter DHNS Command-Trac Part Time 4WD System DJHS 230MM Front Axle DMDS 3.55 Rear Axle Ratio DRJS Dana 35 Rear Axle GACS Tinted Glass Windows GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEHS Fixed Door Vent Glass GNAS Rear View Day/Night Mirror HCDS Do Not Use - See HCA JAAS Instrument Panel JAZS DO NOT USE - See JP, KA classes JBFS Instrument Panel Black Bezel JCAS 85 MPH Primary Speedometer JKBS KWXS DESCRIPTION NOT AVAILABLE K3ZS STRIPE/BADGE/MOLDING/COLOR LAFS Seat Belt Alert-Driver Seat only LBCS Glove Box Lamp LCJS Overhead Ambient Surround Lighting LMAS Halogen Headlamps MB1S Black Front Bumper MFFS Black Grille MHBS MMCS Rear Solid Window MMGS Belt Moldings MMJS Molded-In-Color Fender Flares NAAS Federal Emissions NBAS NBKS EVAP Control System NDAS Catalytic Converter NF5S 23 Gallon Fuel Tank QWBS DESCRIPTION NOT AVAILABLE RACS Open SBAS Power Steering SCBS Steering Whl SFAS Standard Duty Front Shock Absorbers SGAS Standard Duty Rear Shock Absorbers TADS TBCS Compact Spare Tire TBMS Tire Carrier Winch WJKS 15X6.0 Styled Steel Wheels XBSS Pickup Box XFAS -35F Protection Anti-Freeze YAAS Build To U.S. Mkt. Specifications Z5AS GVW/Payload Rating 1AAS U.S. Dealer Retail 133S Zone 33-Philadelphia *B1 DESCRIPTION NOT AVAILABLE -H9 DESCRIPTION NOT AVAILABLE ADH Heavy Duty Electrical Group BA1P DESCRIPTION NOT AVAILABLE BCYP 95 Amp Battery CBAP Straight Back Bench Seat CKA Carpets - Floor and Cargo Area DGB All 4-Speed Automatic Transmissions DHTP Shift-on-the-Fly,P/Time T/Case EAAC All Engines EAFC ERB 4.0L I6 MPI Engine GRZP Left Remote Mirror GSZP Right Remote Control Mirror GTZ Manual Remote Mirrors JJA Cigar Lighter MBJ Black Bumper MDA Front License Plate Bracket PWB DESCRIPTION NOT AVAILABLE RAAC All Radio Equipped Vehicles RCAP Audio TAAC All Tires TNCA P195/65R15 BSW AS Touring Tires YGEA 5 Additional Gallons of Gas Z01P Rear Spring Group I Z66P Left Front Group XV Z85P Right Front Spring Group XIV 5ALA DT-Vehicle Family Link to comment Share on other sites More sharing options...
jdog Posted August 30, 2021 Share Posted August 30, 2021 Next question is @Far McKon in Canada or USA Link to comment Share on other sites More sharing options...
eaglescout526 Posted August 30, 2021 Share Posted August 30, 2021 What a brain teaser. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 30, 2021 Share Posted August 30, 2021 That build sheet says the color is white as in the photo. @Far McKon what does it look like above the brake master? Like the white 88 or the red 89 below? Link to comment Share on other sites More sharing options...
fiatslug87 Posted September 10, 2024 Share Posted September 10, 2024 The ‘89 VIN is correct for this truck, post moved to 1989 registry. Link to comment Share on other sites More sharing options...
