VagaBond Comanches Posted August 17, 2021 Posted August 17, 2021 1989 Base LWB 4.0 5-Speed Manual 79,700 miles - Dent and rust free
eaglescout526 Posted August 17, 2021 Posted August 17, 2021 *X2 TRIM STYLE X2 - VINYL BENCH -SA Charcoal 167 Zone 67-Charlotte 1AA U.S. Dealer Retail 4EA Sold Vehicle 4HC Special Scheduling Condition III 5AL Low Series Tracking APA Monotone Paint BAQ 61 AMP ALTERNATOR BCX Maint. Free Battery BGA Power Front Disc/Rear Drum Brakes BJA STD DUTY FRT DISC BRAKES BKP 10x2.5 Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering CSR Passenger Assist Handles CUM Mini Floor Console DBB All Manual Transmissions DDX 5-Speed Manual Transmission DMM 3.07 Rear Axle Ratio DRJ Dana 35 Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GNA Rear View Day/Night Mirror GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAA Instrument Panel JAZ DO NOT USE - See JP, KA classes JBF Instrument Panel Black Bezel JCA 85 MPH Primary Speedometer JKB K3Z STRIPE/BADGE/MOLDING/COLOR KWW T: BRILLIANT WHITE - NAMEPLATES - W LAF Seat Belt Alert-Driver Seat only LAP Shift Indicator Warning Lamp LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MLDG - TYPE I NAA Federal Emissions NBA LIGHT DUTY CYCLE NBK EVAP Control System NDA Catalytic Converter NF5 Fuel Tank - 23 Gallon PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6 QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6 RAA All Radio Equipped Vehicles RAC AM MTR Radio RCA SBA Power Steering SCB Steering Whl SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TNC P195/65R15 BSW AS Touring Tires WJK 15X6.0 Styled Steel Wheels XBS Pickup Box XFA -35F Protection Anti-Freeze YAA Build To U.S. Mkt. Specifications YGB 1 Additional Gallons of Gas YGG 9 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z58 Left Front Spring Group Viii Z78 Right Front Spring Group VIII Build date 11/1/88 Body code TL62 Sold by SPARKIE'S CHRYSLER DODGE JEEP, FOREST CITY NC
VagaBond Comanches Posted August 17, 2021 Author Posted August 17, 2021 Thanks for the information. Based on the build date, this means I have the Peugeot transmission? I would like to locate a Dana 44 rear with 4.10 gears and Metric Ton leaf springs.
tugboat95 Posted August 17, 2021 Posted August 17, 2021 Yes you have the Puegot. The switch was made on March, 9, 1989 Nice looking truck, ain't many that age around without any body issues.89 ComancheEliminator2wd4.0L5 speed PukeGoatFactory Original
Pete M Posted August 17, 2021 Posted August 17, 2021 26 minutes ago, 89ComancheProject said: Thanks for the information. Based on the build date, this means I have the Peugeot transmission? I would like to locate a Dana 44 rear with 4.10 gears and Metric Ton leaf springs. but it never hurts to check the trans, since a lot can happen in 30 years. that exact 44 would only have been under a truck that had the 2.5L and thus are rare as hell. but a 3.07 or 3.55 geared 44 is definitely find-able and then you would just regear it.
VagaBond Comanches Posted August 18, 2021 Author Posted August 18, 2021 5 hours ago, tugboat95 said: Yes you have the Puegot. The switch was made on March, 9, 1989 Nice looking truck, ain't many that age around without any body issues. 89 Comanche Eliminator 2wd 4.0L 5 speed PukeGoat Factory Original Thanks, I guess I’ll be looking for an AX-15 soon.
VagaBond Comanches Posted August 18, 2021 Author Posted August 18, 2021 5 hours ago, Pete M said: but it never hurts to check the trans, since a lot can happen in 30 years. that exact 44 would only have been under a truck that had the 2.5L and thus are rare as hell. but a 3.07 or 3.55 geared 44 is definitely find-able and then you would just regear it. Thanks for the info.
tugboat95 Posted August 18, 2021 Posted August 18, 2021 Thanks, I guess I’ll be looking for an AX-15 soon. If all you're gonna do it drive it. It's a decent transmission. If your going off-road regularly it's a different story. That being said, I've already got one just sitting and waiting for the original to grenade. And I just drive mine around town.89 ComancheEliminator2wd4.0L5 speed PukeGoatFactory Original
eaglescout526 Posted August 18, 2021 Posted August 18, 2021 Actually according to the catalog only a D44 with a 4.09 ratio could be had w/out the locking diff. 3.54 with a locking diff
