1J7FT26L2KL459155
VagaBond Comanches
*X2 TRIM STYLE X2 - VINYL BENCH
-SA Charcoal
167 Zone 67-Charlotte
1AA U.S. Dealer Retail
4EA Sold Vehicle
4HC Special Scheduling Condition III
5AL Low Series Tracking
APA Monotone Paint
BAQ 61 AMP ALTERNATOR
BCX Maint. Free Battery
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDX 5-Speed Manual Transmission
DMM 3.07 Rear Axle Ratio
DRJ Dana 35 Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JKB
K3Z STRIPE/BADGE/MOLDING/COLOR
KWW T: BRILLIANT WHITE - NAMEPLATES - W
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF5 Fuel Tank - 23 Gallon
PX6 CLASSIC BLACK CLR CT PRIMARY PAINT - FX6
QX6 CLASSIC BLACK C CT SECONDARY PAINT - FX6
RAA All Radio Equipped Vehicles
RAC AM MTR Radio
RCA
SBA Power Steering
SCB Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGB 1 Additional Gallons of Gas
YGG 9 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Build date 11/1/88
Body code TL62
Sold by SPARKIE'S CHRYSLER DODGE JEEP, FOREST CITY NC
26 minutes ago, 89ComancheProject said:
Thanks for the information. Based on the build date, this means I have the Peugeot transmission?
I would like to locate a Dana 44 rear with 4.10 gears and Metric Ton leaf springs.
  but it never hurts to check the trans, since a  lot can happen in 30 years. :D
that exact 44 would only have been under a truck that had the 2.5L and thus are rare as hell.  but a 3.07 or 3.55 geared 44 is definitely find-able and then you would just regear it.  :L:
Thanks for the info.
Thanks, I guess I’ll be looking for an AX-15 soon.
If all you're gonna do it drive it. It's a decent transmission. If your going off-road regularly it's a different story. That being said, I've already got one just sitting and waiting for the original to grenade. And I just drive mine around town.
89 Comanche
Eliminator
2wd
4.0L
5 speed PukeGoat
Factory Original
  • 1 year later...
