Clueless Posted August 6, 2021 Share Posted August 6, 2021 Hello I have a 1987 Comanche, 4wd, short bed Renix 4.0 (ba-10 but we won't talk about that ax-15 coming). My truck did not come with AC or the tow package (I know this because I happen to have the original factory window sticker will attach below). I have no overheating issues currently but am moving to Yuma AZ for work and want to add a electric fan just to make myself feel better. I was looking at Dorman 620-001 (linked below). Am I able to plug this fan directly into the factory wiring harness plug which is located on the driver side fender next to the airbox, or do I need some sort of fan controller in addition to the fan? I am not the biggest fan of electrical work (yes I know renix jeep has all sorts of electrical problems so help me God I'm squashing them one at a time) so I am looking for the simplest solution as possible. Cheers https://www.autozone.com/cooling-heating-and-climate-control/radiator-fan-assembly/p/duralast-dorman-radiator-fan-assembly-620-001/422698_0_0 Link to comment Share on other sites More sharing options...
Clueless Posted August 6, 2021 Author Share Posted August 6, 2021 Link to comment Share on other sites More sharing options...
tugboat95 Posted August 6, 2021 Share Posted August 6, 2021 Check these guys out. You will need something like this.https://www.ksuspensionfab.com/store/p32/Electric_Fan%2FAccessory_Relay_Harness.html#/I'm not sure how your particular model is wired. You will need a relay. This harness is easy to install, they even have a video. The down side may be the switch. You have have to turn it on or off. It is not automatic. Switch comes with it.All that being said, I can't tell the difference with it on or off. That's in the Southeast. Not quite Arizona but 95+ is normal. Some are of the opinion if it comes on for an overheating situation, it's too late. The set point to come on is 218.89 ComancheEliminator2wd4.0L5 speed PukeGoatFactory Original Link to comment Share on other sites More sharing options...
cruiser54 Posted August 6, 2021 Share Posted August 6, 2021 Nothing will "plug in". Link to comment Share on other sites More sharing options...
omega_rugal Posted August 6, 2021 Share Posted August 6, 2021 get a couple of efans out of a taurus and wire them thorugh a relay and a switch, i don't know what seaon is yuma arizona right now but i have heard is hot in summer, if so you can take out the thermostat for now, and go with a mix of 50/50 or 30/70 coolant. better save for some funtional hood vents so hot air gets flushed out of the engine bay as you move... Link to comment Share on other sites More sharing options...
