XJ bucket seat swap
Looking at some XJ buckets to swap into the Comanche. Found these online and I’m not sure if they’re the ones with the curved base? From what I’ve read, if they are they should still work, but will sit a little higher? Can anyone verify from the pics? They look curved to me but I’m not 100%
To answer your question, yes, it will sit higher. I have done this swap. You'll need to experiment with bracket placement to be sure it's going to be mounted comfortably for you. You'll be doing some drilling as well.
Here's my post. It's not a write-up, but maybe it can help.
