NC Tom Posted July 20, 2021 Share Posted July 20, 2021 One day my brakes are good, another day (today), the pedal goes almost to the floor! It still stops, but the pedal travel ain't right. 88 with stock system. The booster has been hissing since I got the MJ a couple of years ago. I cannot build pressure when the truck is on or off. Fluid level is good. Maybe the booster bought the farm? If so, is that a pretty straightforward procedure? Link to comment Share on other sites More sharing options...
TheDude Posted July 20, 2021 Share Posted July 20, 2021 Soft brakes = leak or bad master.Very hard brakes but poor stopping = bad booster.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
cruiser54 Posted July 21, 2021 Share Posted July 21, 2021 Typical master cylinder symptoms. Link to comment Share on other sites More sharing options...
NC Tom Posted July 21, 2021 Author Share Posted July 21, 2021 Oh, okay. Hadn't had a master cylinder go out on me. Didn't know the symptoms. Thanks! Any recommended parts brands? I'm not going to scrounge around a just yard for this. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 21, 2021 Share Posted July 21, 2021 One NOT made in china. Link to comment Share on other sites More sharing options...
NC Tom Posted July 24, 2021 Author Share Posted July 24, 2021 On 7/21/2021 at 6:39 PM, cruiser54 said: One NOT made in china. Okay, so I'm looking online at my options for this repair. I might as well replace the aging booster along with the MC. Now, I'm having to decide which way to go. Reman, new or rebuild kit for MC. I have no experience with this procedure so input is welcomed. I checked the DIY Forum, but only found posts for upgrades and swaps. Not a stock replacement. And @cruiser54 I'm reading that "Raybestos, Wagner, Bendix, Centric, Motorcraft and Delco brake parts are made in China/Taiwan. David Zeckhausen President, Zeckhausen Racing". Who's left? Link to comment Share on other sites More sharing options...
jdog Posted July 24, 2021 Share Posted July 24, 2021 Reman is someone replaced the most common worn out parts, rebuild kits can be tricky but cheap and can be done in a day. Link to comment Share on other sites More sharing options...
NC Tom Posted July 24, 2021 Author Share Posted July 24, 2021 12 minutes ago, jdog said: Reman is someone replaced the most common worn out parts, rebuild kits can be tricky but cheap and can be done in a day. Thanks! I decided to go with a reman from NAPA. This will be an adventure! Link to comment Share on other sites More sharing options...
jdog Posted July 24, 2021 Share Posted July 24, 2021 Its not to bad to do, just make sure to put some rags to catch the brake fluid from going onto the paint when removing the lines and follow exactly how it says to bench bleed. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 24, 2021 Share Posted July 24, 2021 I've used reman on numerous vehicles. Never an issue. Even if you only do the master cylinder now, at least you will have your brakes back. Booster can wait. Ever adjust your rear brake shoes? Now's a good time to do that. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 24, 2021 Share Posted July 24, 2021 Bench bleed the master first. Link to comment Share on other sites More sharing options...
