70barracuda Posted June 29, 2021 Share Posted June 29, 2021 Anyone have a lead on a replacement for that little nylon sleeve that goes on the clutch master push rod and clutch pedal? I can't for the life of me find mine or anything that'll work. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 29, 2021 Share Posted June 29, 2021 Nothin in the Dorman help section? Or under an XJ? I’ll get ya a part number here soon. Link to comment Share on other sites More sharing options...
70barracuda Posted June 29, 2021 Author Share Posted June 29, 2021 1 minute ago, eaglescout526 said: Nothin in the Dorman help section? Or under an XJ? I’ll get ya a part number here soon. Not that I've found. I think this is the # J4007472. But no luck on finding one Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 29, 2021 Share Posted June 29, 2021 https://www.quadratec.com/products/52018_0001.htm?gclid=Cj0KCQjw5uWGBhCTARIsAL70sLIZpCPzr2A00ojHhZIj8owE1EsLIQBdxQuXIGTwBYmLq3j7jh-xMicaApA0EALw_wcB You need 4. Link to comment Share on other sites More sharing options...
70barracuda Posted June 29, 2021 Author Share Posted June 29, 2021 12 hours ago, Jeep Driver said: https://www.quadratec.com/products/52018_0001.htm?gclid=Cj0KCQjw5uWGBhCTARIsAL70sLIZpCPzr2A00ojHhZIj8owE1EsLIQBdxQuXIGTwBYmLq3j7jh-xMicaApA0EALw_wcB You need 4. I believe those are for the axle pedal box shaft. I need the single one that goes on the clutch master pushrod to pedal Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 29, 2021 Share Posted June 29, 2021 1 hour ago, 70barracuda said: I believe those are for the axle pedal box shaft. I need the single one that goes on the clutch master pushrod to pedal There isn't one that I'm aware of. In fact you'll have to drill out a newer master to get it over the pin, mine is a near press fit. I you are metal to metal with slop.......could be your pin is worn. You'll have to measure and hunt something down or make one......or get a new master and drill it out. Link to comment Share on other sites More sharing options...
Jeep Driver Posted June 29, 2021 Share Posted June 29, 2021 Go with Wilwood and use a heim joint. Grind off your pin and drill it out for a grade 8 bolt to the heim. Just another option. That would also give you a little adjustment that you currently don't have. Link to comment Share on other sites More sharing options...
70barracuda Posted June 29, 2021 Author Share Posted June 29, 2021 I have the wilwood master already. I had taken a new master with a plastic eyelet and threaded it on the rod, the jeep push rod is just different enough it wouldn't sit in the wilwood master. But it sits at an angle and is definitely messing with my pedal pressure. I ordered a heim and will try to make it work without cutting the piece of the pedal first Link to comment Share on other sites More sharing options...
