Refinishing Wheels
I have a set of pretty decent eliminator wheels that 3 of 4 have essentially no corrosion but the clear coat is gone. One of them has minor corrosion but I think that it can be repaired without losing the machined finish.
Should I have these chemically stripped and recoated with something? Is clear powder coat better than 2k clear? Any idea best method to prep these?
I used aircraft stripper years ago and it worked out great! The old clear lifted right off, I then gave them a good rinse with water, and they were finished up with fresh clear.
Powder coating is obviously going to be lot stronger and that's important when it's battling road debris all day, but I really don't think that makes up for its cost.  A good 2k is also a lot clearer, but I don't think you'd notice without a side-by-side.  I would personally go with a 2k.
X2
3 minutes ago, Torq_Shep said:
Does anyone have any experience with using real 2k without primer? I have PPG 2k clear that I can spray them with but I am worried about adhesion.
I’ve shot some on bare steel with good results. I’ve never used rattle can 2k, just traditional 2 part clear with hardener. I wonder how an epoxy clear would turn out. Those epoxy coatings are supposed to be super tough with excellent adhesion without any primers.
