renix cruise troubleshooting without tester?
There are number of tests you can perform with just a DVOM and a test light.  The module just helps narrow down the places to test.
The steps are detailed in the 88 electric service manual.
Pretty much what 87 said. A test light can do quite a bit but something that it can’t do is trigger the solenoid to engage which makes it challenging if you need to test the solenoid.
Do you have factory installed parts, your own from a donor or one of my kits?
Is there a way to test the vac side with a vac pump?  If I pull vac at the servo it should hold correct?  Just thinking of ways to narrow it down.  I was told by the seller of my cruise stuff that he never had it working so no idea if the brain is even any good.  I am going to Rons on sunday.  I think he has a brain box or 6... :laugh:
I might actually have him beat there. But you should be able to test the servo and the lines with a vac pump. I recommend trying to give the servo power while using the vac pump to verify the servos internals are working.
