found something good at the junkyard
88swampedmj
i was at the junkyard the other day lookin for a good radiator for my red truck and came accross this.. the best part is the bed is rhino lined! so iam gonna get the bed off it, clean it up.. pull the dents and put it on my red truck
i plan on painting the red one dark grey sometime and doin the 97+ front clip and a little lift
Image Not Found
Image Not Found
Image Not Found
i forgot to say,
the sucky thing is someone t boned the drivers side it got the bed just a bit but not too bad,
how much is a rhino linning? is it worth the work for that bed?
and one more little edit... if you look you can see a light on the back of the cab ive never seen that on a mj.. i had to take that and i may put it on mine it looks stock.. were they options? its a 89 eliminator
the seats have already been takin otherwise i woulda got them to
and yes iam thinkin the harness is intact still. no wirring was messed with on it.. someone took the seats.. the guage cluster.. front clip and a few other things
but if you want ill get you that harness
and w/e else anyone wants
i have the side vents too from it
