jdog Posted June 14, 2021 Share Posted June 14, 2021 Ok reverse lights check for a trans fuse in the fuse box, for the top bulbs I would be checking to see if you have a good ground Link to comment Share on other sites More sharing options...
Muncher Posted June 14, 2021 Author Share Posted June 14, 2021 Ok reverse lights check for a trans fuse in the fuse box, for the top bulbs I would be checking to see if you have a good groundOk. I just re did my ground though I replaced cracked parts of the wire. Brushed down to bare metal and used a actual bolt on it. Link to comment Share on other sites More sharing options...
scaleless Posted June 14, 2021 Share Posted June 14, 2021 27 minutes ago, Muncher said: But if I put them in the top they don't but normal bulbs Do which makes no sense to me Make sure they're the exact same bulb type. They can look similar but be different enough to not work e.g. have a shorter base and not make an electrical connection. 28 minutes ago, Muncher said: in guessing it's the switch for them? Test for +12v when you're in reverse and that'll answer your question. Link to comment Share on other sites More sharing options...
Muncher Posted June 14, 2021 Author Share Posted June 14, 2021 Test for +12v when you're in reverse and that'll answer your question.For the bulbs being the same the I only used two led blinkers and one is currently on each side but when I put two normals bulbs on one side and both leds on the other it wouldn't blink. Which is why I'm confused Link to comment Share on other sites More sharing options...
jdog Posted June 14, 2021 Share Posted June 14, 2021 What normal bulbs are you installing? Link to comment Share on other sites More sharing options...
Muncher Posted June 14, 2021 Author Share Posted June 14, 2021 What normal bulbs are you installing?Just the ones that were already in thr truck Link to comment Share on other sites More sharing options...
jdog Posted June 14, 2021 Share Posted June 14, 2021 1157 or 56? Link to comment Share on other sites More sharing options...
Muncher Posted June 14, 2021 Author Share Posted June 14, 2021 1157 or 56?How am I supposed to tell? Link to comment Share on other sites More sharing options...
jdog Posted June 14, 2021 Share Posted June 14, 2021 They should say on the base, also 1156 have one element, 57 has two Link to comment Share on other sites More sharing options...
Muncher Posted June 14, 2021 Author Share Posted June 14, 2021 They should say on the base, also 1156 have one element, 57 has twoLed and normals are both 57 them they have 2 elements Link to comment Share on other sites More sharing options...
Muncher Posted June 15, 2021 Author Share Posted June 15, 2021 Still having this problem Link to comment Share on other sites More sharing options...
Muncher Posted June 19, 2021 Author Share Posted June 19, 2021 Just commenting again. Still can't put leds in the top socket for some reason Link to comment Share on other sites More sharing options...
jdog Posted June 19, 2021 Share Posted June 19, 2021 Just a guess here but bad sockets Link to comment Share on other sites More sharing options...
Muncher Posted June 19, 2021 Author Share Posted June 19, 2021 Just a guess here but bad socketsMaybe. Any idea on a name for them? Link to comment Share on other sites More sharing options...
