ratrapp Posted May 23, 2021 Share Posted May 23, 2021 the end of my kickdown cable broke off when i tried to hookup my new weber carb.the carb end must be a little larger so when i went to hook the cable up the plastic end broke off.does anybody know of a source for this cable?i looked online but didnt see anything.i know the 86 with the 2.8 is the redheaded stepchild of mj's but it serves the purpose for right now.i would gladle swap the 904 out for something else if anybody has any suggestions.it is a 2wd for now but plans for 4wd are in the future so i don't want to spend a fortune on a 2wd tranny. Link to comment Share on other sites More sharing options...
omega_rugal Posted May 24, 2021 Share Posted May 24, 2021 you could reattach the the cable with some wire while you find a replacement Link to comment Share on other sites More sharing options...
watchamakalit Posted May 25, 2021 Share Posted May 25, 2021 I used an aftermarket lockdown cable kit from lokar when I swapped the 904 into my cj. Might be an option worth checking. Link to comment Share on other sites More sharing options...
