russel730 Posted May 18, 2021 Share Posted May 18, 2021 2.5L 2WD base model AX-4 Dana 35 Original paint was red but was resprayed with a Maaco single stage at some point. Tan interior. Bought in NC in 2018 (3rd owner) came with pretty complete original paperwork. Haven't pulled the carpet yet but it's as rust free as you can get I'd imagine. 168k current miles Currently bone stock for the most part. PO swapped to open cooling and 91-95 power steering pump. Factory A/C possibly? I have yet to see another where the alternator is installed above the A/C compressor. Maybe that's what they did for dealer installed A/C? REM, Mean Lemons battery cables, headlight relays are next up on the list. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 19, 2021 Share Posted May 19, 2021 *X1 -YY APA MONOTONE PAINT PACKAGE CBA BENCH SEAT - STRAIGHT BK CGX Head Restraints-Outboard Seating, RR DCB Transmission - 4-Speed Manual EPD ENGINE - 2.5L I4 TBI GAS GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MD8 Delete Front License Plate Bracket NAA ESA W/CATALYST (EXC CALIF SYSTEM) PE4 Colorado Red QE4 Colorado Red RAC RADIO - AM/MTR TBG SPARE TIRE - COMPACT WMC BASE WHEEL DRESS - UP (INCLS TRIM RING) That looks like dealer installed AC. My 84 XJ has that similar set up. Build date 9/2/86 Body code TL61 Sold by JIM TESTA JEEP-EAGLE, KINGS MOUNTAIN NC Link to comment Share on other sites More sharing options...
russel730 Posted May 19, 2021 Author Share Posted May 19, 2021 Thanks Eaglescout. In my forum lurking over the last couple years I've gandered at your Little Red here and there. She's a beaut. Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 19, 2021 Share Posted May 19, 2021 21 minutes ago, russel730 said: Thanks Eaglescout. In my forum lurking over the last couple years I've gandered at your Little Red here and there. She's a beaut. You’re welcome and thank ya! I’ll be keeping an eye out on your MJ and to what you have planned. Pretty nice survivor right there. Link to comment Share on other sites More sharing options...
Pete M Posted May 19, 2021 Share Posted May 19, 2021 4 hours ago, russel730 said: Thanks Eaglescout. In my forum lurking over the last couple years I've gandered at your Little Red here and there. She's a beaut. never assume the floors are clean. ANY mj can have rust under the carpet. all it takes is one of the various common leaks and rain gets under and does the damage. Link to comment Share on other sites More sharing options...
russel730 Posted May 28, 2021 Author Share Posted May 28, 2021 On 5/19/2021 at 3:00 PM, Pete M said: never assume the floors are clean. ANY mj can have rust under the carpet. all it takes is one of the various common leaks and rain gets under and does the damage. Oh, I'm sure they're not 100% clean. I definitely have plans to redo the interior and coat the floors after I clean them up. Link to comment Share on other sites More sharing options...
