Rol Fogs
Hey for people with rols I could use some help. #1 is what wire goes to which inside the housing #2 where do I find a bulb for these mine just falls out when I put it in. And #3 is there a fuse for the system because when I turn them on the light in the switch does not turn on.
I can probably answer three with a question. How did you set up the wiring for them?
1, only one wire should be going in to the housing itself and the other one should be ground which is commonly denoted by the wire color being black.
2, I can probably find the bulb number in the catalog.
I think I found the bulbs on Amazon. But there is two wires I'm pretty sure are the same color. I'll have to check again in the morning
2 minutes ago, eaglescout526 said:
Ok that makes more sense. Have you checked the relay to ensure it’s working? I assume you’ve cleaned all the grounds prior to this.
I have not. Where would the relay be located.
8 hours ago, eaglescout526 said:
Relay would be located in your relay center…hopefully. If not it’s in the engine bay somewhere then.
That would be where all the fuses are in the driver's side foot well?
No. The relay center is under the hood. That black cover that’s got the fragile clips holding it in place.
Oh ok. I don't have the plastic peice. But do you know which relay it would be
